Old 06-11-2019, 09:56 AM   #1
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
(FS) Feeler - Complete Daily/All Season Setup for 1LE or ZL1
Please delete this post if feeler threads aren't allowed.
These items are located in Greenville, SC area. Message me or post below with offers. I would be wiling to drive about an hour to meet someone who is close to avoid shipping charges if needed. I also have Family in TN and FL so I might could arrange to bring them there as well.
I'm looking to see what the market is for my current daily/all season setup on my SS 1LE. This is a complete ready to go set of tires, wheels, lug nuts, 20MM spacers, sensors, and TPMS relearn tool. I specifically chose these tire sizes to most closely match the OEM diameters on the SS 1LE and ZL1 but this setup will still work fine on the other 6th gen camaros. The only difference is the front tire is slightly wider and slightly smaller diameter. It lowers the front of the car 8.5MM and still is only a 2.5% speedo error on the front. The 20MM spacers are also the closest match to the OEM fitment, meaning the wheels sit flush with the fenders as the 1LE and ZL1 do instead of sitting further inboard like the other 6th gen camaros. This setup perfectly accomplished my goal of maintaining the OEM fitment in diameter and offset while giving me a longer wearing well mannered daily commuter tire.
With this setup you can swap the wheels out in your garage and reprogram the sensors and be on your way.
Although this setup is narrower than the 1LE and the ZL1 its still as wide as the PP Mustang GT and the BMW M3/M4. With the spacers this setup still has an aggressive sporty look.
Here is the list of parts this setup has about 5K miles on it so tons of life left on the tires. Can measure tread depths later if requested.
- 5 spoke silver 6th gen Camaro SS wheels w/ center caps
(Front: 20X8.5 et25 Rear: 20X9.5 et39)
- General G-MAX AS-05 All Season Tires (500TW / 50K mile)
(Front: 255/35 Rear: 275/35)
- Supreme Engineering Technologies 20MM Hub Centric wheel spacers
(66.9MM center bore w/ 5X4.75 / 14X1.5 studs)
- OEM 6th gen Camaro SS TPMS sensors
(Retains all OEM functions with temp and psi readouts and full PTM functionality)
- OEM 6th gen Camaro silver/chrome lug nuts
- GM Tire Pressure Monitoring System calibration tool
Below is an illustration of the fitment comparison beweeen the SS 1LE / ZL1 OEM Setup and my all season setup with 20MM spacers installed. The third image below is the comparison to the OEM Camaro SS front.
Old 06-20-2019, 01:12 PM   #2
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Bump
Anyone looking for a daily setup on their ZL1 or SS 1LE?
Old 06-20-2019, 01:46 PM   #3
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Can you post pictures of the spacers?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 06-20-2019, 02:28 PM   #4
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Sure! You want pics of the spacers themselves or fitment comparisons?
These are the marketing images they had when I purchased them. I will get shots of mine so you can see the current condition as well.
