06-10-2019, 01:45 PM | #1 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Condensation on the inside of the lense of my Gauge Cluster
So my Gauge Cluster lense is full of water spots. At first I thought it was on the outside of the lense and I tried to clean it with glass cleaner. Absolutely nothing changed. Went over it 3 - 4 times and it's still exactly the same.
Should bumper to bumper cover this? Attached image. |
06-10-2019, 03:14 PM | #2 |
Wow Need4, never seen anything like that before! Very strange and yes I would think it is covered under your warranty since yours is a 2017.
06-10-2019, 03:41 PM | #3 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
That looks horrible, but yes, it's supposed to be sealed and is a single unit, it should be covered by bumper to bumper warranty.
06-10-2019, 03:49 PM | #4 |
Drives: 2017 Chevrolet Camaro 2.0 LT Join Date: Apr 2017
Can you feel it on the outside, like with your fingernail? Maybe some chemical or cleaner got sprayed up there that etched it?
06-10-2019, 03:59 PM | #5 | |
If its etched, is it possible to fix it? I only just noticed this today, we had a pretty bad rain storm here in Austin last night but Im baffled how my gauge cluster could have been effected by it if it was. |
06-10-2019, 04:06 PM | #6 |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
If it doesn't go away once the temp in your cabin changes, it's probably not condensation. Take it to the dealership and see what they say.
06-10-2019, 04:15 PM | #7 |
i have it also but on my cruze but its mostly because i vape in my car with the windows rolled up lol happen on my cobalt ss also o well
06-10-2019, 04:23 PM | #8 |
Went outside, ran my finger across. The plastic feels smooth to me. Tried scratching with my finger nail, no changes nor do I feel any difference.
06-10-2019, 06:33 PM | #9 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
When you sprayed stuff on it did it soon different or could you see the spot through the liquid. If it looked different, it may be like a scratch on the paint when it gets wet.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
06-10-2019, 06:44 PM | #10 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
06-10-2019, 10:13 PM | #11 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Possibly a leak around the windshield let some water in? Was the car out in the rain?
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
07-19-2019, 09:20 PM | #12 |
Sorry for the long delay on this. I havent had much free time lately. The dealership says that the lense is etched by armorall or some plastic protectant. I use 303 protectant and I usually only spray the rag and dont remember seeing this when used it last on the dash. When I run my fingers across it I feel no difference. When I scratch at it, nothing absolves or comes off. If it is etched how do I fix this or do I need a whole new gauge cluster?
07-19-2019, 09:57 PM | #13 |
Drives: 2018 LT 1LE Join Date: May 2019
You can try polishing it, like a similar procedure to plastic headlight repair. Try polishing first, if it doesn't work then you will have to sand it down with a 2500 grit or finer, then polish. If you're not mechanically inclined then find someone who's done it before cause it can definitely get worse. If you do decide to do it, make sure you mask the surrounding area so you don't accidentally scratch other things. Good luck.
07-19-2019, 10:16 PM | #14 | |
