![]() Drives: all sold, getting another soon.. Join Date: May 2019
1LE Spoiler options
The carbon fiber 1LE GM spoiler is a thing of beauty. But for less than 1/10th the cost, you can get this ebay version...
![]() ![]() Wondering if any other cheap ass mofos sprung for it and how they feel about it, have pics, etc. Thanks |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
LT4, you get what you pay for! If it was me and I wanted to change to the GM part then spend the money and get the OEM Carbon wing! You will probably be happier in the long run you know!
![]() Drives: 2018 Camaro 1SS. A8, NPP, MRC Join Date: Sep 2018
I’ve bought two parts from Extreme Dimensions under the Carbon Creations brand (same as Duraflex but with CF molded around the parts). The splitter looked very nice out of the box, but the first diffuser I received looked very unfinished and I sent it back to be exchanged. Second one looked better so I kept it. There was about 6 MONTHS of working with them to get both correct parts in good condition (first they sent wrong splitter also).
I had both professionally installed, and the installer said that neither part fit perfectly and they did their best to manage the gaps. The splitter’s gap is not noticeable thanks to its position, but the diffuser has pretty significant gaps from the body. The spoiler *should* be much easier to fit since it only has to fit over three screw holes, but there very well may be issues/modifications required. Pretty much everything went wrong that could have, so if you can afford anything else I would go that route. This is another budget option but it’s probably better than Extreme Dimensions/Duraflex: https://extremeonlinestore.com/colle...=5670298058783 Sent from my iPhone using Tapatalk |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
If you don't mind doing a bit of work on it and re-painting/dipping/wrapping, then go for it (this is the worst case scenario in most cases). Make sure you follow OEM procedures during install.
Or you can fly off with this bad boy: https://www.battleaero.com/collectio...t-camaro-gen-6 j/k This one is Carbon fiber, cheaper than OEM, you get the real look: https://www.c7carbon.com/2016up-cama...on-fiber-p-671 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
lol duraflex? nope im good
I purchased the C7Carbon carbon fiber one, ordered around a month ago. The price is a 1/4 of the GM one, and looks identical in person (I saw one at Cars ad Coffee). Once mine arrives I can fill you in on my experience.
The one above OP (I believe) is the one that shakes at high speeds.
ARH 2" Long system to stock suitcase / VVT3 cam/ RotoFab Big Gulp/ IW Balancer with 9.1 Ring/ Stock Upper/ HD Belt/ NGK Plug Set/ Taylor Wire set with Head Shields/ Tuned at Lashway Motorsports
#7 | |
![]() Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
C7Carbon | ZL1 ILE style rear wing | IN DEVELOPMENT, 3D TECH! Go to post #533 there are some pics of this wing on a members car that helped me decide to purchase along with talking to Matt at Wildhammer Motorsports that I find to be a stand up guy. The wing really looks nice! |
#8 |
#9 |
I agree LT4! That definitely looks better than the wing type of the Z1LE! IMO the wing on the ZL1 1LE looks ricer but it’s a track car so I understand why it was designed like that.
