Old 06-10-2019, 07:16 AM   #1
tmmk11roberts
Drives: 2011 Camaro RS/SS
M228 Front Fitment Issues 2016 2SS
I am having a rubbing issue when I went to install my MRR M228 wheels on my 2016 2SS. I had these wheels on my 2011 and no problems. I am running the 20x10 with a 275/40 20 in the front. It is rubbing on the strut at the spring pocket. I am wondering if a 3mm spacer would be enough to alleviate the rub. Has anyone had this issue?
tmmk11roberts is offline   Reply With Quote
Old 06-10-2019, 07:27 AM   #2
JeromeS13
Drives: 2017 1SS/1LE
Without even factoring in the wider wheel, you went from this to this... Your front tire is 1" larger in diamater than stock...
Old 06-10-2019, 08:06 AM   #3
tmmk11roberts
Good info! So what I think I am going to try is using a 5mm spacer to see if it will free me up. I just ordered a set from Wildhammer Motorsports. Hopefully it works...
Old 06-10-2019, 08:13 AM   #4
JeromeS13
Chances are, with a 5mm spacer, you will not have adequate thread engagement on your lugs/studs. I would not recommend it.
Old 06-10-2019, 08:23 AM   #5
tmmk11roberts
I will try it and if it doesn't work I will send them back. As long as I can still engage the hub at full install and have around 10 pitches on the lug I should be okay. Thank you for your advice and concern...fingers crossed it will work.
Old 06-10-2019, 10:47 PM   #6
MosaicX1LE
Drives: 2017 MBM Camaro V6 1LE
FWIW, there is a 12mm offset difference between the 5th gen offset for the M228 and the 6th gen offset for the M228.
MosaicX1LE is offline   Reply With Quote
Old 06-11-2019, 01:26 PM   #7
DarrenMRRWheels
DarrenMRRWheels's Avatar
Drives: 2016 Camaro SS
Mosaic is correct.
We manufactured 20x10 with +35mm offset for 2010-2015 that fits front or rear.
We also have the 20x10 +23 that fits all year Camaros and clears the strut 6th Gen with no issues.
I dont believe the 5mm spacer will be enough, but give it a try. If not, we have the +23mm in stock almost all of the time.
Thanks
Darren
DarrenMRRWheels is offline   Reply With Quote
Old 06-14-2019, 11:03 AM   #8
tmmk11roberts
What would 2 of the +23 cost me? I believe the rears will be okay.
Old 06-14-2019, 12:08 PM   #9
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
pm sent
Carlos_MRRWheelsInc is offline   Reply With Quote
