Old 06-09-2019, 09:54 AM   #1
L78toLT1
L78toLT1's Avatar
Wideband HPTuners problem
Hey guys, I made this video for Ted Jannetty to see if he can determine why my wideband is not talking to HPTuners. Ted and HPTuners initially thought the problem was with my gauge, but Ted replaced the gauge and nothing has changed. I'm new to HPTuners, so the issue may be on my end. I thought I would post the video here to see if anyone could help. I'm sure Ted will chime in tomorrow, but I thought I would post here to see if anyone on the forums could help.
Baby Blue
Old 06-09-2019, 10:39 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Mine has been randomly doing the same thing but you might try this.
-Delete the current WB PID and disconnect HPT scanner.
-Put the car in Accessory mode by holding the start button with foot off the brake for 5-10seconds.
-After the wideband heats up and switches on, connect the HPT scanner.
-Select Add Pid.
-In search box type "Wideband"
-AEM device should show up in external controllers.
-Add that PID to the list, Start car, and Start scanning.
This is the only way to get mine to work and it will be fine for 2-3 different logs then start acting up. My guess is a software glitch.
Old 06-09-2019, 11:32 AM   #3
L78toLT1
L78toLT1's Avatar
You're the man, King! Worked like a charm!
Baby Blue
Old 06-09-2019, 05:53 PM   #4
KingLT1
KingLT1's Avatar
Glad to hear!
Old 06-10-2019, 09:07 PM   #5
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Oh I was watching the video before I read further down that King figured it out. I was going to also suggest that you had to use the AEM specific PID and not just a Generic WB Ratio 1 selection.
Dysan911 is offline   Reply With Quote
Old 06-11-2019, 12:13 AM   #6
squish72
Drives: 2016 2SS 8AT
-Select Add Pid.
I have the exact same issue and found the same as the only way to fix it.
It used to work non stop Everytime. Now its hit or miss. Messed up a few logs I was taking because I didn't notice till after that it wasn't logging it.
squish72 is offline   Reply With Quote
Old 06-13-2019, 08:52 AM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks for the help on this guys seems to be a new problem that cropped up recently.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 06-13-2019, 09:38 AM   #8
grampa_ss
grampa_ss's Avatar
Have you guys tried the "repoll for supported parameters" option?
if Wideband not reading.
1. click blue stop scanning
2. click on disconnect from vehicle
3. click connect to vehicle
4. click vehicle/Repoll For Supported Parameters
Old 06-16-2019, 07:19 PM   #9
TJay74
I had to use the repoll option, then used the WB EQ term in the channel list and it added the WB EQ just fine. Has worked that way since day 1.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 06-16-2019, 09:46 PM   #10
laynlo15
Drives: 2022 Lt1 A10
Kings always showing off. Ha
