Old 06-08-2019, 11:52 AM   #1
Brandonc_06
Drives: Chevy Camaro 2017
6 speed manual question
I just got headers put on and tune. When i step on it hard my transmission goes to neutral and rev match turns off. Any reason to why its doing this?
Brandonc_06 is offline   Reply With Quote
Old 06-08-2019, 12:36 PM   #2
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
Lose engine / trans mounts?
Dixie ZL1 is offline   Reply With Quote
Old 06-08-2019, 12:52 PM   #3
AchiliesSS
AchiliesSS's Avatar
Drives: 2017 Black on Black 1SS
Most definitely sounds like a short in a wire somewhere or there is something in your tune dealing with the skip shift maybe. Just a 2 cent guess and plus slot of people have had clearance issues with headers first being installed to where they were creating weird issues and turned out to be headers rubbing and melting wires.
AchiliesSS is offline   Reply With Quote
Old 06-08-2019, 01:44 PM   #4
Brandonc_06
Slip?
Just got headers and tune done. I floored it twice from like 5 mph and it will go into neutral and turn my rev match off. I have a 6 speed manual. Then i tried it from like a 50 roll and it didnt go into neutral. Any reason why it would do this?
Old 06-08-2019, 02:07 PM   #5
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
I've never had that happen before. I would either record it to show exactly what's happening or, take it to a shop to have them look at it. I wouldn't take it to a dealership, however.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 06-08-2019, 02:51 PM   #6
Who's tuning your car?
Old 06-08-2019, 05:23 PM   #7
Brandonc_06
A friend who uses hptuner. Hes been doing it for 10 years. It was a street tune. You think it has something to do with a tune?
Old 06-08-2019, 09:34 PM   #8
The rev match stuff makes me think that and earlier you mentioned O2 sensor issues. You really need a dyno tune and have someone check it out.
Old 06-18-2019, 04:46 PM   #9
Walter_
Drives: 2018 1LS Camaro
The only thing a dyno is good for is bragging. So your transmission is jumping out of gear. That is not in the tune. Does the engine stay under power? What are the RPM before and after? It is hard to get a transmission out of gear under power. What gear does it do it in?
Walter_ is offline   Reply With Quote
Old 06-21-2019, 04:29 AM   #10
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
a non load baring dyno is only good for bragging. a load baring dyno is good for getting a proper tune with out getting tickets or going to jail for excessive speeding. trans going out of gear has nothing to do with the tune. something mechanical is wrong. if the skip shift was screwed up it would lock you out of 2,3, and 5th it wont bump it out of gear.
Old 06-21-2019, 10:01 AM   #11
RuthleSSchevy
RuthleSSchevy's Avatar
Drives: 2016Camaro+1968Chevelle+1954BelAir
My thoughts exactly. Lowered the trans brace for header instal and dident tighten it back up
"Lead me, follow me, or get out of my way." GGSP
RuthleSSchevy is offline   Reply With Quote
Old 07-12-2019, 08:50 PM   #12
7speed
Drives: 21 SS
U mean seems like neutral while in gear or physicallys sticks moves to neautral?
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 07-13-2019, 12:31 AM   #13
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
do you have TC or Stabilitrak enabled?
Try it in race mode with everything off.
I'm pretty sure there is a safety mechanism where if it senses a large amount of torque in a short time, it kills the throttle.
protovack is offline   Reply With Quote
Old 07-13-2019, 08:41 PM   #14
Brandonc_06
Probably has been fixed. It was wiring harness being shorted by my headers.
