Old 06-06-2019, 04:36 PM   #1
guyjusthere
guyjusthere's Avatar
Drives: 2016 2SS Camaro
2SS headlight flicker out
Last week I noticed my passenger side hl was yellow when driving out of my garage in the morning.
2 days later the passenger light was out at night. Sometimes it flickers when I turn headlight switch on/off.
Is this a hl or harness I replace?
Should I replace both at the same time? (4500 or 5000k?)
What are we buying for replacement bulbs (company & part#)?
I just went out of warranty last month...
2016 Camaro 2ss (has full hid and led hl package included)
Thanks! I'm big on buying quality parts
guyjusthere is offline   Reply With Quote
Old 11-06-2020, 10:49 AM   #2
DWS909
DWS909's Avatar
Drives: 2016 Camaro 1LT RS Turbo
Did you find the issue, mine just started doing the same thing. Was it just the bulb or ballast?
DWS909 is offline   Reply With Quote
Old 11-08-2020, 02:40 PM   #3
Vaska
Drives: On Hiatus
Start by swapping bulbs left to right to see if the issue follows before dropping money on bulbs, harness or ballasts. Flickering could mean a number of things but start with the easiest.
Vaska is offline   Reply With Quote
Old 11-08-2020, 04:19 PM   #4
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Sounds like the bulb is dying. Usually HID bulbs will shift colour right before they die. If you are lucky, you might see them turn purple/pink right before they die.
In the past, I used Philips X-tremeVision gen2 which is a 5000K bulb. It gives off a very nice and white clean look. Good output, too.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 11-29-2020, 02:40 PM   #5
Justin_Swift6
Drives: 2016 Hyper Blue Metallic 1SS
Mine was exactly the same, flickers at start etc, just swapped the bulb and everything is fine now.
Philips 42302C1 D3S Standard... https://www.amazon.com/dp/B008BRJ712...p_mob_ap_share
This is the OEM bulb that I purchased.
Justin_Swift6 is offline   Reply With Quote
