Old 06-01-2019, 05:18 PM   #1
GT-ER
Drives: 2018 Camaro ZL1
Took my whipple ZL1 to the dyno today and don't know what to think...
Took the car today to the dyno to see how much power she's putting down and I'm surprised at how low the numbers were considering the mods and that the tune really looks to be good.
I put down 645whp and 710wtrq.
I'm surprised torque was much higher than HP. It was on a Dyno Dynamics and the run was done in 6th gear (couldn't be done in 7th because the DD was limited to 150mph). Ambient temp was 95*F outside and probably closer to 100 inside.
Mods are:
Whipple with 3.5 upper and 9.10 lower
2" Headers, 3" Hi flow Cats, AWE Touring Exhaust
RotoFab CAI
1 Step colder plugs
Weapon X upgraded heat exchangers
JMS Fuel Pump Booster
93oct with meth
Stock Long Block
A/F was around 11.5-11.8 and timing was around 21* with 0 KR.
Maybe I'm just used to seeing dynojet numbers that are much higher or maybe doing the pull in 7th would have given me better numbers...I don't know. Maybe the lack of a cam or stock TB is what's really killing power up on top.
Anyone have any thoughts on this?
GT-ER is offline   Reply With Quote
Old 06-01-2019, 05:40 PM   #2
RDBill
902HP 858TQ
RDBill's Avatar
Drives: 2018 ZL1 A10
How does it feel driving it? Looks like the A/F is in the ballpark... I would think you may need a low side fuel system especially with a stock cam but i'm no expert.
I'm not familiar with that dyno... my car has only been dynoed on a Dynojet. I would think in Texas you have a few tuners in your area if you wanted to dyno it again on a better day and a different dyno.
RDBill is offline   Reply With Quote
Old 06-01-2019, 07:19 PM   #3
GT-ER
Sorry, forgot to add that I have a JMS voltage booster for the LPFP. Fuel pressure is rock solid.
Yeah, I'll end up just going somewhere else to give it a try I suppose. Ultimately I suppose it doesn't really matter, car pulls hard as hell. Even my Toyo R888R's have a hard time putting the power down under 40mph.
Old 06-01-2019, 07:59 PM   #4
DangerZL1
Drives: 2023 Black ZL1 Auto
Was the car tuned on a dyno after the build?
Old 06-01-2019, 08:01 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
100 degrees in the dyno room sure as hell didn’t help.
Definitely leaving power on the table with the stock TB. The 95mm TB is so inexpensive, that’s a no-brainer for you to add on.
Old 06-01-2019, 08:46 PM   #6
01cbr929
Drives: Which one?
DD reads significantly lower than DJ.
01cbr929 is offline   Reply With Quote
Old 06-01-2019, 09:13 PM   #7
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
You should get a 5" intake, ZR1 TB and have it retuned. PD blower cars making north of 650 rwhp really react well to less restriction before the TB. Just my .02
I would be disappointed that your tuner, didn't know this or recommend it. (whoever they are)
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 06-01-2019, 10:06 PM   #8
GT-ER
Car was tuned on the street, not dyno.
I've seen people put down over 750whp on stock TB, while I don't doubt it doesn't help my case to still run the factory one, I doubt just upgrading the TB will give me an extra 100hp. Granted, I guess Dynojet vs. Dyno Dynamics may be why. I have thought about it though, but traction is already an issue so I don't know what to do...
Old 06-01-2019, 10:17 PM   #9
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
How much boost are you seeing with that combo?
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 06-01-2019, 10:35 PM   #10
GT-ER
16-17psi.
Old 06-01-2019, 10:54 PM   #11
HoldMyBeer
Drives: 2017 ZL1(Silver) - A10, Stock
So, when I had my 03 Cobra tuned over 10 years ago on a dyno dynamics dyno, I was told the difference between DD dynos and dynojets was approx 12%. So applying that factor it puts you about 725 rwhp.
Hope it helps.
2017 ZL1(Silver) A10
HoldMyBeer is offline   Reply With Quote
Old 06-02-2019, 12:24 AM   #12
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Dyno Dynamics is the heartbreaker dyno, without a base line you really have nothing to compare.
gotswap is offline   Reply With Quote
Old 06-02-2019, 03:33 PM   #13
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Mine did 665 on 93 no meth. Stock cam kooks with green cats roto fab and a 103 Tb. 13 pounds of boost. On e40 it made 698 and was running out of fuel. I also have the booster. My tq is no where near yours. 639
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 06-02-2019, 04:51 PM   #14
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Seems low on the HP side, but there are so many variables involved. Dyno numbers are really just a by-product of how an engines performs. If it runs strong on the street then no worries. Another dyno on a cooler day may give a whole different result. I would not give these numbers any worry.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
