Old 05-28-2019, 08:16 PM   #1
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
LT4 Pulley setup
Hey guys im trying to find a pulley combo that would help me get to 10PSI.
Currently the car is at 8psi and havent been tuned for e85 yet but will very soon before doing so I would like to raise the boost a bit... I know that with a 2.5" I can probably reach this psi but I cant find anyone sellinga zPE pulley in this size... Maybe the experts here can advise on how I can achieve this PSI? Maybe by adding a lower pulley, if so? which one (%) can I get?
Current mods:
2019 ZL1 LT4 blower 2.75" ZPE griptec pulley
LT4 HPFP
LT4 Inyectors
1 7/8 Headers
3" exhaust
Roto-fab CAI
Might Mouse catch can
E85 Flex fuel sensor
Edelbrock exp. tank
Any help appreciated
Florida High Performance: H/C Whipple LME 377 900WHP
G2K is offline   Reply With Quote
Old 05-29-2019, 08:20 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
http://www.z-industries.com/lt4-z06-...2-pulley-only/
Old 05-29-2019, 08:46 AM   #3
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Z06 pulleys would work on ZL1? I thought there was some slight changes?
Is not, this would definetly bring me up to 10PSI you think? I have stock ZL1 lower crank pulley
Old 05-29-2019, 09:09 AM   #4
KingLT1
KingLT1's Avatar
I am not 100% but I believe the hub is different between platforms but the pulley is the same. Either way if it doesn't fit, next option would be calling ADM performance. They specialize in LT4 swaps.
Old 05-29-2019, 09:54 AM   #5
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
If thats the case I should be golden... Asking around I was able to get one local funny what shows up when you just ask :P....
Thanks again KingLT1.
Old 05-29-2019, 05:47 PM   #6
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Current mods:
LT4 HPFP
LT4 Inyectors
1 7/8 Headers
3" exhaust
Roto-fab CAI
Edelbrock exp. tank
What kind of WHP levels do you typically see on 93 straight?
Who did the tuning?
Did you replace pistons? Adjusted the stock ring gaps?
Old 05-30-2019, 08:51 AM   #7
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Who did the tuning?
I havent been to the dyno, just put the blower on the car... Will be tuned remotely, stock pistons.
Old 05-30-2019, 09:29 AM   #8
Markoz28
Drives: 18 ZL1 nightfall grey A10
pretty sure Weapon X can hook you up with a Griptech 2.5 pulley.
By chance did you use the 95mm TB on the LT4 blower?
Markoz28 is offline   Reply With Quote
Old 05-31-2019, 06:55 PM   #9
Eldi Z
Good luck with the tune.
Who is your remote tuner?
I shall follow your build, since the LT4 SC setup is also my future plan.
Old 06-01-2019, 11:01 PM   #10
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Pray Performance
Old 06-05-2019, 07:10 AM   #11
Drsagacity
Drsagacity's Avatar
I think you could check the ATI balancer/hub/lower supercharger pulley and that might be a really easy way to go. Pretty sure if you change the lower pulley to 10% overdrive you will pick up a couple pounds of boost.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 06-05-2019, 07:17 AM   #12
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Stupid me I sold it as Im not going to port the blower and didnt find any data using the adapter plates that are out there. So I just went back to a Ported 87mm
Yeah my thoughts too, Anyway I was able to find an 2.5 griptec pulley. So thanks to all for your inputs.
