Old 05-25-2019, 03:35 PM   #1
ddanj
Drives: 2018 1LS 1LE
V6 rear brakes scan tool needed?
So I'm reading the instructions on how to replace rear pads. Because we have the electric parking brake as part of the caliper, the instructions call out to attach a scan tool and issue "Rear Brake Caliper Piston Retract". And after the job is done the scan tool is used to "Calibrate the park brake".
Is this really needed? What if I don't do it?
BTW I'm planning to replace pads and rotors.
Thanks!
2018 Garnet Red 1LS 1LE V6 w/Tech
1100 - 07/26/2017 | 4300 - 09/15/2017 at rail yard
3000 - 08/16/2017 | 4200 - 09/18/2017 shipped!
3100 - 08/19/2017 TPW 09/11/2017 | 4800 - 09/20/2017 train journey done
3400 - 08/25/2017 | 5000 - 09/22/2017 at the dealer, and picked up!
4300 - 09/12/2017 Built! VIN available
4B00 - 09/14/2017 move to rail yard
ddanj is offline   Reply With Quote
Old 05-25-2019, 08:48 PM   #2
ddanj
These are the instructions I have...
Old 05-26-2019, 03:40 AM   #3
Drew145022
Drives: 2017 Camaro 2SS Vert
This is something I need to know also. I do not need to replace my brakes currently but I will eventually
Drew145022 is offline   Reply With Quote
Old 05-26-2019, 07:37 PM   #4
ddanj
I ended up basically following these directions to back out the parking brake:
https://youtu.be/wAB43eO7wIs
So far so good. No warning lights or anything.
Attached are a few of my pics. Looks similar to what you see in the video.
Didn't need to use scan tool with EPB function. Yay!
Old 05-27-2019, 12:14 AM   #5
Drew145022
Thanks that really helpful.
Old 05-27-2019, 05:24 AM   #6
ddanj
Sure, no problem!
I'm a little surprised no one posted this info before, oh well.
Old 05-27-2019, 09:32 AM   #7
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Great info.
Old 04-17-2020, 12:58 PM   #8
jimrhodes
Drives: chevrolet camaro
I hope everything is fine with your car now. Maybe you have some recent photos to share here or maybe https://resume-chief.com/best-job-search-engines here?
jimrhodes is offline   Reply With Quote
Old 04-18-2020, 04:37 PM   #9
EWard
Drives: 2019 Camaro RBM M6 LTG 1LS
This makes total since. I replaced my brake pads and had a real hard time pressing the rear piston back in with proper tools and I was wondering why it was being such a pain in the ass . Now I am questioning if I messed up the rear calipers doing this. The G-Loc track pads seem great, but I was expecting more and wonder if the rears are not giving me all that they have because of my stupid blunder
Anyone have experiencing doing what I did and can shed some light?
Thanks,
EWard is offline   Reply With Quote
Old 04-20-2020, 02:38 PM   #10
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Thanks,
Possibly. IIRC, the motor basically turns a screw that pushes on the back of the piston instead of hydraulic pressure. It'd be pretty tough to get that screw to turn just from pushing on the piston, so depending on how you tried pushing on it it's possible you might have damaged something on the caliper. Tough to say without seeing it, though. As long as the park brake still works, you're not leaking brake fluid through the piston seals, and nothing is visibly deformed you're probably fine.
However, most of your track braking response is going to be dependent on the front brakes so I'd put my money on those, not the rears. Depending on which front calipers you're using, your issue might just be with the caliper itself no matter what pad you have on it. I'd also suggest getting the brake duct kit from the SS and installing that. You'll have to either tap the holes on the control arm or just force the screws in with an impact driver, but that'll help a lot with brake cooling for you since there's a decent change you're overheating the brakes with all the stock parts on the 4cyl car.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
