Old 05-21-2019, 11:49 AM   #1
CurbIsTrack
Drives: 2018 Camaro 1LE
Which is the correct TPMS part number
Ordered the MRR SS 1LE replication wheels for a rain setup and wanting to have the TPMS display as I find the Tire Temp display helpful. There seems to be 2 different TPMS part numbers - one is 13598787 and the second is 13598786 for FE4 suspension.
I have a 2018 SS 1LE with mag ride and FE4 suspension (at least as I understand from the build sheet) - can some confirm that I need the 13598786 TPMS part?
Seems like this should be intuitive but I find conflicting info and woud like to get this right the first time.
Please educate me.
CurbIsTrack is offline   Reply With Quote
Old 05-21-2019, 12:31 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
For a 2018 SS 1LE you want 13598787. 13598786 is a different frequency.
Edit: To further clarify, the two different frequencies aren't compatible with each other as grandpa mentions below. 13598786 goes on the non-1LE 4 and 6 cyl Camaros, and 13598787 goes on everything else.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-21-2019, 12:40 PM   #3
grampa_ss
grampa_ss's Avatar
I agree with Alpha1BC. Because I initially bought the 13598786 and they did NOT work.
Then bought the 13598787 and they worked perfectly. Don't forget the EL-50448 relearn tool.
Old 05-21-2019, 02:22 PM   #4
CurbIsTrack
Ordered the VXDAS EL-50448 Auto Tire Pressure Monitor Sensor TPMS Relearn Reset Activation Tool OEC-T5 for GM Series Vehicle from Amazon and got 2.
thanks for clarifying - much appreciated.
