Old 05-21-2019, 10:07 AM   #1
Whatwarranty
Drives: 2016 camaro ss
Automated brake bleed
Instead of going to the dealer I found a scan tool that will do the automated brake bleed to get air out of the abs. It’s called the maxicheck pro $204 on Amazon. Once you get it you will need to register on autels website and update it. Then hook it up and go.
Whatwarranty is offline   Reply With Quote
Old 05-29-2019, 04:15 PM   #2
verdicaysen
verdicaysen's Avatar
Drives: 18' 1SS 1LE HyperBlue
I want to hear any opinion's on this as well.
verdicaysen is offline   Reply With Quote
Old 06-15-2019, 02:35 PM   #3
mblum
Drives: 2017 ZL1 Camaro
I take it you have used this on your car? I was just looking for a scan tool of some sort that could do this without spending $1000.
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle
mblum is offline   Reply With Quote
Old 08-08-2019, 10:41 AM   #4
mblum
For anyone else looking at this tool to perform the ABS bleed, I contacted the seller on Amazon and they told me this would not work on a 2017 Camaro.
OP, have you used one of these on your car?
Old 08-12-2019, 02:21 PM   #5
DenverTaco07
DenverTaco07's Avatar
what is automated brake bleed and why does it require a scan tool?
sorry, i'm lost on its purpose.
Old 08-12-2019, 10:56 PM   #6
mblum
Its needed to bleed air from the ABS block, it actuates the internal valves to aid bleeding. This is only needed to bleed the ABS and not needed to bleed calipers.
abs, automated, bleed brakes, brake
