Old 05-17-2019, 09:53 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
just asked a company about a e85 gauge. If i could splice into the sensor for the ECU
they sell the gauge with and without a flex fuel sensor so I asked if it was possible to run the gauge off the flex fuel sensor I already have in the car for the ECU. this is the response I got back.
You can splice into the signal wire off of the sensor harness. But please keep in mind this can skew data.
Thank you
ok so I can do it just the gauge wont read right and if the gauge wont read right i imagine the ECU wouldnt get the right reading so what would be the point of installing this gauge?
Old 05-17-2019, 02:04 PM   #2
Jeb114
Jeb114's Avatar
Drives: 2021 300
Because Chevy will not tell aftermarket companies how to read there data or how to intrepid there algorithms.
Jeb114 is offline   Reply With Quote
Old 05-17-2019, 02:35 PM   #3
parish8
Drives: 17 SS a8
The flex fuel sensor outputs a frequency and a pulse width. You can double tap that and it does not effect the signal.
The freq/ratio is known, I think I have that data at home but it is also on the net. There is fuel temp data in that signal too.
Old 05-17-2019, 04:45 PM   #4
parish8
Drives: 17 SS a8
Old 05-17-2019, 07:50 PM   #5
JCunningham
Drives: 2017 2SS M6
if you have the ECU and the gauge hooked up to the same sensor will the 2 draw to much power and offset the signal.
0volts = 0% ethanol 5volts= 100% ethanol
https://www.innovatemotorsports.com/...CF1_Manual.pdf
Old 05-17-2019, 10:34 PM   #6
parish8
Drives: 17 SS a8
the sensor does not output a 0-5 volt signal. it outputs a frequency. same with the maf sensor. you can double tap these without effecting the signal.
most 0-5 volt output sensors can be double tapped with a very slight effect of the reading.
Old 05-17-2019, 10:58 PM   #7
JCunningham
Drives: 2017 2SS M6
in the manual for the sensor it says voltage for the outputs to data log. https://www.innovatemotorsports.com/products/ecf1.php i definatly dont want either reading to be off at all
Old 05-17-2019, 11:14 PM   #8
parish8
Drives: 17 SS a8
those are outputs from the innovate controller. those are not the inputs to the innovate controller from the flex fuel sensor.
the flex fuel sensor outputs frequency and pulse width. the frequency matches the picture above. 50hz = 0% ethanol and 150hz = 100% ethanol.
double tapping the sensor does not effect the frequency and does not effect the reading.
if you have doubts hook up a scan tool to the factory ecm and log ethanol ratio then add in the wiring to the innovate controller and see if the reported % on the factory ecm changes. it wont.
Old 05-17-2019, 11:20 PM   #9
JCunningham
Drives: 2017 2SS M6
thanks I believe you. i think I will get it with the sensor though being its only an extra $34. I dont want to add another sensor to the line as I would have to buy another Racetronix adaptor and make a new fuel line. might as well have the sensor if mine ever fails.
Old 05-19-2019, 10:29 AM   #10
BlueinTN
Drives: gas powered
Thank you
I figured it was Innovate right when I read this the other day.
hey at least they respond to you they wont to me at all and I have 500$ worth of there products plus I used to recommend them to others.
Im not sure they know how there own products work.
https://forum.autosportlabs.com/view...03f4a707cc7458
i been reading this.
BlueinTN is offline   Reply With Quote
Old 05-20-2019, 09:41 AM   #11
51FIFFT
Drives: 2017 2SS M6 FIFTY @51fifft
Why not just get the AF interceptor gauge?
51FIFFT is offline   Reply With Quote
Old 05-21-2019, 02:54 AM   #12
JCunningham
Drives: 2017 2SS M6
didnt know about it. but i also want to data log with HP tuners so having the obd2 port covered wont work.
Old 05-21-2019, 02:56 AM   #13
JCunningham
Drives: 2017 2SS M6
i got the gauge on ebay for $10 more then the one without the E85 sensor.
Old 05-21-2019, 06:40 AM   #14
51FIFFT
It's a nice gauge. You can just disconnect it while data logging. I have it and the AEM with pass through plug. Simple install.
