Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 05-16-2019, 11:06 PM   #1
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
New Tire Mounting Issues
Has anyone had any problems with tire stores damaging their ZL1, say with the lift the cars go up on during wheel removal process? I just want to insure things end up right. I know that there only certain points you can lift these cars from without damaging them. Thanks in advance.
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 05-17-2019, 06:53 AM   #2
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
When I first purchased my 2014 Convertible I had heard some wild stories of dealerships as well as local garages jacking of lifting our cars without using the proper jack locations. I believe thee was one photograph some time ago of one owner's Camaro that actually fell of the Dealer's lift.
Placing a floor jack or lift arms in the wrong locations could very easily cause damage to the factory seams.
Even though I read the owner's manual and I knew the proper jack points I wanted to MAKE SURE anyone that worked on my Camaro also knew. For this I purchased a complete set of the RED lift pads from ZL1Addons. My Camaro is Ashen Gray so the Red lift pads really stick out, I want them visible! I will post one picture that if you look closely you can just barely see one mounted at the rear of the car. Recently when I took my Camaro to the dealership to have the brake fluid flushed I told the tech, "make sure you use the installed red jack pads for lifting the car. After the job was completed the very same tech said to me "those jack pads are really nice, takes the guessing away"! OMG
Will be money well spent!
Deputy347k9 is offline   Reply With Quote
Old 03-16-2020, 12:33 PM   #3
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Rather than bargain shopping, you need to go to a good shop w/ expensive rims. Any hack can remove a tire and mount it. Care must be taken w/ expensive rims.
Have this shop buy you two new rims and go to a proper tire shop.
JB'sZL1 is offline   Reply With Quote
Old 04-03-2020, 02:39 AM   #4
MADDOGG79
MADDOGG79's Avatar
Drives: 2013 Chevrolet Camaro ZL1
I bought another set of wheels for a drag set up but was wondering how it would work as far as having the TPMS set up. Can you have that many sensors programmed to you car.
MADDOGG79 is offline   Reply With Quote
Old 05-14-2020, 02:21 PM   #5
eyebuck
Drives: BMW X6
You have to pay attention to what type of TPMS is on the vehicle. If the sensor is at the valve, it has the potential to be damaged.
eyebuck is offline   Reply With Quote
Old 05-14-2020, 03:07 PM   #6
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
I have always had two sets, but bought a program tool for under 100 bucks.
ZMEnow is offline   Reply With Quote
Old 01-11-2022, 02:03 AM   #7
gillanubhav4
Drives: EFW
Can you have that many sensors programmed to you car. hellodear.in
teatv.ltd
gillanubhav4 is offline   Reply With Quote
