![]() Drives: 2017 2SS Garnet Red Convertible Join Date: Sep 2016
Took my 6th gen vert into the dealership to investigate why water has been leaking in around my passenger window. They took the door panel off and told me that because it's not completely body colored on the inside (garnet red), it appears this is not the original factory passenger door and was probably taken from a black Camaro and painted red. (See attached photo.) They are saying because of this, the fitment on the door isn't correct, causing the leaking. I bought the vehicle used, so I don't know if this is the original door or not, but I don't recall seeing anything on the Carfax relating to the passenger side. I'm trying to confirm this theory. Does anyone know if for sure the door would be completely red inside and out if it was the original? Help greatly appreciated!
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
Man dealerships will try anything and everything to deny warranty work on vehicles.
![]() ![]() Drives: 2021 300 Join Date: Jan 2015
Doors and Bodies are dipped at the factory that door was sprayed. Looks like the door was replaced..
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
I think the primer color is more of a beige tan. So maybe they are right.
![]() Drives: 2019 Camaro 2SS Join Date: Jan 2019
Pull the panel on the other door and see if they match.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
unfortunately you find that Carfax is not always complete and accurate. Contact place you bought it from.
Adjusting a door can be tricky, but not that much. Why they won't do it on warranty is BS. EDIT: Aren't there VIN or ID numbs stamped on these?
2012 Yukon XL Denali w/ 6.2 AWD |
#7 |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
go to a different dealer.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#8 |
I will try contacting the dealership I bought it from, but I doubt I'll get any help from them, since I purchased the vehicle over a year ago. The dealership that looked at the car said that I need to take it to a body shop, because if you move the door up to fit better around the window, it opens a gap at the bottom for water to enter.
#9 |
Wouldn't that indicate frame damage?
The door is a door. They're the same size for all Camaro's. |
#10 |
#11 |
#12 |
![]() Drives: Camaro Join Date: Jun 2015
I wouldnt believe carfax
I did a carfax on my honda accord and it has no record of an accident. However I was in an accident years ago where I had to replace my bumper and trunk. |
#13 |
Yeah carfax doesn't have everything on it. I had a 2010 Civic Si that got sideswiped and when the body shop did the work it had bondo on it and had been repainted from a prior accident, totally clean carfax.
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
No they not, the only time the car is dipped is for the EPO coating, otherwise the cars are sprayed by robotic painters just like any body shop would do other than the use an electrical charge to draw the paint to the panels.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
| Tags |
| door, factory, leak, panel, window |
