Old 05-13-2019, 05:45 PM   #1
MPLJR1222
MPLJR1222's Avatar
Drives: 2018 Camaro 1SS
New Exhaust Suggestions??
So I've had my current exhaust set up for about a month now. When I first bought the car, I immediately bought the Borla ATAK axle back, which sounded great. About a month ago, I added the Borla 60610 mid pipes, which, unsure why, actually made the car much quieter when idling or cruising.
Without going into headers and such, are there any suggestions to make it louder while cruising and idling, other than purchasing a different axle back portion?
2018 Camaro 1SS | A8 | Black | GM CAI | Borla ATAK Cat-Back Exhaust
MPLJR1222 is offline   Reply With Quote
Old 05-13-2019, 06:52 PM   #2
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Cut out the cats
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 05-14-2019, 06:41 PM   #3
MPLJR1222
MPLJR1222's Avatar
Originally Posted by BruceWayne1LE View Post
Cut out the cats
I would if I wasn't concerned about my warranty unfortunately
Old 05-15-2019, 01:00 AM   #4
BruceWayne1LE
Deleting the secondary cats shouldn’t void the warranty.
492WHP 473WTQ
Old 05-15-2019, 07:47 AM   #5
VinnAY
Drives: 18 1SS/1LE
I think with the axle back and midpipe that you're already down that rabbit hole.
Old 05-15-2019, 08:15 AM   #6
Bayles76
Bayles76's Avatar
Drives: 16 Summit 2SS, 92 Arctic Formula
Assuming you have already removed your secondary, non-monitored, cats.. no. There is nothing else you can really do to get "louder" other than remove the primary's which will throw a code.
2016 2SS / Summit White / Adrenaline Red / MRC / NPP / CF5 / 5LQ 6 Piston front brakes with slotted & vented 2 piece rotors / A8 / Satnav / Low Gloss Black 5 spoke
Bayles76 is offline   Reply With Quote
Old 05-15-2019, 08:23 AM   #7
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Take that midpipe out.....
Old 05-15-2019, 11:03 AM   #8
MPLJR1222
MPLJR1222's Avatar
That was a thought, but I still dont understand how a pipe that's pretty similar to the stock pipe, except that it gets rid of the flattened section, could make the car quieter, especially at idle or cruising
axle, borla, camaro, cat, exhaust
