Old 05-13-2019, 02:06 PM   #1
VinnAY
Drives: 18 1SS/1LE
Adhesive remover for wheel weight goo
Can you recommend a solid product to get the goo off without paint damage to the wheel? I had my A/S and summers swapped out and of course there was a weight change on one wheel the they left the adhesive backing from the old weights. I wouldn't presume that basic Goo-Gone is going to get the job done here.
Edit: WD-40, perhaps?
Old 05-13-2019, 02:41 PM   #2
KirkH
Start with Goo Gone. There are several types. Automotive is the one I'd start with. Let it soak. Use a plastic scraper tool.
Next, I go to Turtle Wax Label & Sticker Remover. It's a little stronger and gets almost everything off.
Then Stoner Tarminator Tar and Sap Remover. Much stronger, use gloves. Again plastic scraper tool.
One of those will get it off.
Old 05-13-2019, 03:24 PM   #3
VinnAY
Drives: 18 1SS/1LE
Gracias...will play around with it tonite, unfortunately will have to jack and pull the wheel in order to make an attempt at it, not acceptable installed but I may try that before jacking.
Old 05-13-2019, 03:44 PM   #4
KirkH
Heres my thread on full wheel detail off the car:
https://www.camaro6.com/forums/showt...l+wheel+detail
Old 05-13-2019, 04:25 PM   #5
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Thanks for the info
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 05-13-2019, 04:39 PM   #6
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
plastic razor blades... solvent of your choice
thank me later
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 05-13-2019, 04:56 PM   #7
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
CarPro Tar-X works great with any adhesive based products, or get a rubber wheel and it won't tear up the paint
warren3537 is offline   Reply With Quote
Old 05-13-2019, 08:25 PM   #8
VinnAY
Drives: 18 1SS/1LE
I found some similar to goo-gone orange product and as it turn's out it worked pretty well with not much elbow grease and a rag. soak, let it sit, rub, worked OK for what I needed.
Old 05-14-2019, 10:42 AM   #9
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Little late to the game here, but this stuff is awesome!!!
driven2exceSS is offline   Reply With Quote
Old 05-14-2019, 11:30 AM   #10
KirkH
I have a Malco account and use several of their products, but that product has a big warning on it for causing cancer so be careful with that one!
Old 05-14-2019, 07:36 PM   #11
driven2exceSS
Thanks for the heads up
Old 05-15-2019, 07:53 AM   #12
VinnAY
Drives: 18 1SS/1LE
ah yes Cosmoline...you guys familiar with that product? I can still smell it...from being a prior collector of surplus firearms from Eastern Europe, cosmoline is just plain nasty to clean out of a rifle. Used as a storage preservative/protectant.
Old 05-15-2019, 08:28 AM   #13
driven2exceSS
Not too familiar, but have been using it here and there since going to the NAPA dealer that carried the product line to find something that WILL work on the residue after removing the sun visor warming decals. Kirk is much more in tune, I'm not a detailer or anything close. But I did just use it for the very purpose of the wheel weight goo
Old 05-15-2019, 09:07 AM   #14
KirkH
Malco makes good products that work. I am just up to my elbows in the chemicals every day so i try to avoid the ones that have cancer warnings.
