Old 05-12-2019, 09:26 PM   #1
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
New ZL1 hits the ground running DFW area makes 647 RWHP 2 MODS
This is my 2019 ZL1 1LE A10 camaro. The car was purchased and immediately taken to AMP in Grand Prairie (after some breakin time of course!!! LOL). Below is the DYNO chart for the car. The CAR BONE STOCK made 574 RWHP and 581 TQ. With a TUNE and ROTOFAB you can see the car made 600 rwhp and 610 TQ. A flex fuel sensor was added and the car now makes 647 RWHP and 645 TQ. on E85. All these pulls were done with the stock pulley setup which resulted in about 11 pounds of boost. The END result is the car makes 73 MORE HP and 64 more TQ than it had to begin with. MORE TO COME.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 05-12-2019, 09:41 PM   #2
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
Originally Posted by sr71bb View Post
This is my 2019 ZL1 1LE A10 camaro. The car was purchased and immediately taken to AMP in Grand Prairie (after some breakin time of course!!! LOL). Below is the DYNO chart for the car. The CAR BONE STOCK made 574 RWHP and 581 TQ. With just a tune you can see the car made 600 rwhp and 610 TQ. A flex fuel sensor was added along with a ROTOFAB intake and the car now makes 647 RWHP and 645 TQ. on E85. All these pulls were done with the stock pulley setup which resulted in about 11 pounds of boost. The END result is the car makes 73 MORE HP and 64 more TQ than it had to begin with. MORE TO COME.
That is great. I just received my ZL1 1LE A10 as well. But I'm loathe to kiss my warranty goodbye with a tune like you did (unless you know something I don't about maintaining warranty).
ohsmily is offline   Reply With Quote
Old 05-12-2019, 10:40 PM   #3
Bain
Drives: 2019 Shadow Gray Metallic ZL1
Nice power. My 19 A10 only put down 554 rwhp
Bain is offline   Reply With Quote
Old 05-13-2019, 04:11 AM   #4
BigumZL1
BigumZL1's Avatar
Drives: 2017 ZL1 Summit White
Really pondering doing the E85 upgrade myself along with the LT4 throttle body. Seems like really good power without too much modification. Did you add an additional AFR gauge?
BigumZL1 is offline   Reply With Quote
Old 05-13-2019, 04:19 AM   #5
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Stout numbers for sure
Old 05-13-2019, 07:16 AM   #6
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
What mix of e85 you running?
jvandy50 is offline   Reply With Quote
Old 05-13-2019, 07:56 AM   #7
staples87
Drives: 2017 Camaro ZL1
If only E was available in my neck of the woods...
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 05-13-2019, 08:04 AM   #8
Baldilocks01SS
Baldilocks01SS's Avatar
Drives: SEARCHING
Every Dyno is different and conditions are different. It's more for a baseline.
Baldilocks01SS is offline   Reply With Quote
Old 05-13-2019, 10:22 AM   #9
sr71bb
sr71bb's Avatar
Dyno run
No additional AFR gauge was added. E85 was regular pump E85 gas like what you get from your friendly KROGER store (LOL).
Retired Cars BELOW:
Old 05-13-2019, 10:36 AM   #10
jvandy50
i'd love to be able to do that, my local stations have always measured at 77%.
you may be the first I've seen running without a mix
Old 05-13-2019, 10:44 AM   #11
MaskedRacerX
MaskedRacerX's Avatar
Drives: Now: GT/PP Vert, Future: ZL1 Vert
Right, I've seen people say "E85" but it's really Flexfuel (not 85% ethanol) - like here's a local station, it's got the big 85 on the pump but it clarifies the actual ethanol content at 51-83%.
FWIW, I haven't used it, or tested the %, I was going to get a Flexfuel tune on my GT, and now I'm going to trade it for a ZL1, though I'm still interested in a Flextune
MaskedRacerX is offline   Reply With Quote
Old 05-13-2019, 10:55 AM   #12
sr71bb
sr71bb's Avatar
E85
Good point. To REALLY get true E85, you would probably have to get something like Sunoco Fuel E85-R. Regardless of what the percentage alcohol is though, the flex fuel sensor will adjust for it. You simply wont make as much power obviously with lower grade fuels.
Retired Cars BELOW:
Old 05-13-2019, 11:03 AM   #13
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
So...
E85, tune, and cold air kit 647
DSX Flex 300.00
Rotofab 495.00
Install ?
Tune 600.00?
$1395.00 plus labor....
vs.
Headers, cut box w high flow filter, and 1 pulley swap on 93 and same power..
ATI 918856W Damper $325.00
ATI 916227 or Lingenfelter L220170709 135.00
GATES Greenback k080845HD 28.00
Texas Speed Headers $599.00
LS1 ATI 951499 damper bolt summit 9.75
NGK 6510 1 step cooler plugs 80.00
Tune $600.00
Labor I did my self 0.00
$1,776.75
If you would of replaced the stock air filter with a green.. then cut the bottom out of the box.. YOU COULD LAY CLAIM to 650 hp for 900.00 bucks at same power level! Holy Cow that's cheap!
Great job!
So you didn't need an Aux pump or other plugs? Also what was tune and labor?
Old 05-13-2019, 11:13 AM   #14
sr71bb
sr71bb's Avatar
What is your point exactly???
Retired Cars BELOW:
