Old 05-11-2019, 03:49 PM   #1
Destroyer_1LE
Destroyer_1LE's Avatar
Drives: 2017 Camaro 1LE
NEW 18" APEX WHEELS on my 1LE
Wheel Spec:
Front: Apex SM-10 18's 10.5 et22 with a 8mm spacer upfront with hub centric rings
Back: Apex SM-10 18's 10.5 et22 with hub centric ring
Tires:
Front and Back: Michelin Cup 2 Track Connect 295/30r18
You can also find more photos on my instagram @Destoryer_1LE
https://www.instagram.com/destroyer_1le/
I just realized I made a mistake in the video by saying 8mm hub centric spacer when its 12mm hub centric Spacer. When I say 3mm I really mean 5mm non hub centric spacer. Sorry for the mistake.
I put together a little video talking about the spec and fitment.
2017 Camaro SS 1LE
Instagram: @Destroyer_1LE
Sponsor: Tires: Michelin, Wrap: Protective Film Solutions, Wheels: APEX RACE PARTS
Destroyer_1LE is offline   Reply With Quote
Old 05-11-2019, 04:16 PM   #2
NickyRacerBoy
Drives: 1LE
sorry if i missed, who makes or made centric spacers?
NickyRacerBoy is offline   Reply With Quote
Old 05-11-2019, 04:19 PM   #3
Destroyer_1LE
I can't believe I just realized Ive been saying the wrong sizes. I meant to say 12mm hub centric spacers and 5mm non hub centric spacers.
Heres a link to the ones that I'm using:
https://www.apexraceparts.com/access...pacer-kit.html
2017 Camaro SS 1LE
Old 05-11-2019, 06:25 PM   #4
NickyRacerBoy
Drives: 1LE
I was going to machine a centric spacer that would adapt/convert from GM size to BMW centric sizes.
Old 05-11-2019, 06:58 PM   #5
Destroyer_1LE
I thought about doing that, however it would be way too expensive to do it myself.Like 2-3 months back I got bored and modeled a set in CAD. If I was a machinist or had a friend with a shop that has a CNC machine I would have had them made and make them available to everyone.
2017 Camaro SS 1LE
Old 05-11-2019, 10:32 PM   #6
Move_Over
Drives: ISO ss 1le
Very nice, same setup as me! Little different spacer and tire config though.
Move_Over is offline   Reply With Quote
Old 05-11-2019, 10:53 PM   #7
Destroyer_1LE
Soon I will be getting a second set so I can run Michelin Slicks.
What spacer are you running?
2017 Camaro SS 1LE
Old 05-11-2019, 11:25 PM   #8
TrackClub
TrackClub's Avatar
These tires must have TREMENDOUS grip
Sorry couldn't help myself lol!
Old 05-12-2019, 07:13 AM   #9
Move_Over
Drives: ISO ss 1le
5mm up front. I have camber plates though, allows me to get the strut out of the way to run that small of a spacer.
Hah! They do!
Old 05-12-2019, 07:58 AM   #10
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Perhaps you mean 'camber bolts'? With plates, the tire to strut clearances are fixed.
Norm
Old 05-12-2019, 09:19 AM   #11
NickyRacerBoy
Drives: 1LE
YEAH THEY MUST BE
Old 05-12-2019, 09:36 AM   #12
Move_Over
Drives: ISO ss 1le
Nirm
No, camber plates. With 18” the wheel to strut clearance is still not enough due to the shape of the strut, so i still have to run a 5mm spacer with 18” wheels. With 19” and 20 inch wheels you’re right, it totally fixes the clearance.
Old 05-12-2019, 10:51 AM   #13
Norm Peterson
Camber plates won't fix strut inclination relative to the wheel; that's fixed as long as you're not using the Camaro's OE camber adjustment down at the knuckle.
But yes, strut-side clearances get tighter as wheel diameter gets smaller (I think it's by about 3mm per inch of wheel diameter change).
Norm
Old 05-13-2019, 02:22 PM   #14
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
Norm
With the camber plates you can get the camber you want without maxing the camber at the knuckle. You can set the knuckle back to ~0*° which gains your clearance.
RXtacy is offline   Reply With Quote
