05-09-2019, 10:28 AM | #1 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Factory Alignment Warranty
PSA - GM only covers the factory alignment on these cars up to 7,500 miles. If you're under that than I highly recommend you get it done through a dealership.
Some of the alignment bolts on these wonderful machines are TTY (one time use only) which means that if they are loosened to align the car they must be replaced. While I'm curious to know what kind of torque values we're talking about, it doesn't take away from the fact that a TTY bolt 'should not' be re-used. I personally have about ~8,400 miles on mine (not a DD), and I have noticed uneven tire wear to the outsides of all four tires. Was told yesterday that yes, the camber is out on all four tires and in addition to the new TTY alignment bolts the front end needs to have a "strut grind". In total it's going to cost ~$450 for a four wheel alignment, which isn't crazy expensive but, I wanted to get this out there for awareness. |
05-09-2019, 10:57 AM | #2 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Did you see the MESS of my alignment in the other thread?
I have only 2k miles, showed the dealer, they will do the alignment next week.
ZL1::J-E-T-S JETS JETS JETS |
05-09-2019, 10:57 AM | #3 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Thanks for the heads up. I think it's normal for manufacturers to limit the time they'll cover an alignment. Can you explain what a "strut grind" is?
05-09-2019, 11:43 AM | #4 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Yep, so much can happen when leaving the lot to throw it out of whack. Surprised the coverage is even that long
05-09-2019, 11:44 AM | #5 |
I think they are coming out of the factory way off.
05-09-2019, 12:09 PM | #6 |
That was on my mind when I purchased. I wanted to have it checked before I drove off the lot but I had to beat a snow storm on a 450 mile trip home. So far my tires @2000 miles are wearing pretty even.
I have a Ram 3500 that just ate through the front tires in 10k miles. Took it in and the alignment was WAY out of whack. Lesson learned.…. |
05-09-2019, 12:47 PM | #7 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
05-09-2019, 01:07 PM | #8 |
05-09-2019, 02:22 PM | #9 |
After touring the BG Corvette factory and watching the alignment on a C7, it's amazing the alignment is as close as it is. If the Camaro line is similar, any new one should be aligned before delivery if possible.
05-09-2019, 03:51 PM | #10 | |
Flyin NOE
Knowing what I know now, I would have demanded an alignment right after delivery and right before going over 7,500 miles. Either the factory alignment is sketchy at best (in all these cars) or they don't hold an alignment for shite. |
05-09-2019, 03:55 PM | #11 | |
Flyin NOE
I am going to ask when I pick the car up tomorrow and will report back - if nothing else I'm curious as well. |
05-09-2019, 05:34 PM | #12 |
Speed Racer
Drives: 2017 ZL1 Join Date: Oct 2008
I learned the hard way when I found horrible wear on the outside of the passenger front tire. Took it in at 8500 mi as was told too bad, there is a 7500 mi limit. This is BS, the factory should be replacing the tires and aligning for what is a factory defect.
05-09-2019, 06:31 PM | #13 | |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
The mention of the TTY bolts has me concerned. I'm getting a track alignment done in a couple of weeks and I'm wondering how this will apply to my ZL1 1LE. Which bolts specifically and if anyone can chime in about the ZL1 1LE. Thanks.
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________ 2005 NISSAN TITAN 1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18 2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD |
05-11-2019, 10:32 AM | #14 |
Flyin NOE
So, the guy who does the alignments in the shop left before I got to the dealership yesterday so I wasn't able to ask what he did. Apparently this cat has been doing alignments for a long time and he's a bit of a stickler for details.
How the service manager explained the 'strut grind' to me is that in order to get some cars an alignment that is truly dialed-in, they sometimes have to do some grinding where the strut mates with the frame - I believe it's a clearance issue with the bottom of the strut but, I'm still not 100% sure what the hell it does. At any rate, it was less than an hour worth of labor for the 'strut grind'. Here's my before and after: Last edited by kwav8r; 05-11-2019 at 03:43 PM. |
