Old 05-07-2019, 02:12 PM   #1
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Factory alignment numbers inside how bad is it?
Some of you may already know, I don't like the way the car feels on highspeed hits. regular driving it seems to need constant steering wheel correction. Seems to hydroplane in the rain too easy. My old 17 Zl1 did not have the above issues. I have an appointment at the dealer next week to fix the alignment. I took the car to an alignment shop today to record some numbers so I can show the dealer. numbers look bad, LOL. Any alignment gurus have an opinion? How bad is it? brand new car!!!
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 05-07-2019, 04:02 PM   #2
DangerZL1
Drives: 2023 Black ZL1 Auto
Curious why the shop that set it up on the alignment rack didn't make any adjustments?
Old 05-07-2019, 04:06 PM   #3
Alain
Alain's Avatar
+1.
what kind of numbers did the shop get you? Hope you have a good dealership. I don't trust them with my car one bit.
My parking brake has given me problems on two occasions and I'm having a hard time getting myself to bring the car to the dealer and letting them touch it.
2018 ZL1 1LE/Red hot
Old 05-07-2019, 04:06 PM   #4
mblum
Drives: 2017 ZL1 Camaro
I'm no guru but it is not uncommon at all for a brand new car to have a poor alignment. Looking at your spec sheet fixing the toe is going to make a noticeable difference during street driving, especially if the roads are not perfect. If you do not track the car just shoot for to the specs you have outlined on the attached GM spec sheet. If you do track the car go more aggressive and shoot for the track alignment called out.
FYI, the first time I took my car to the track it had the as delivered specs. About 4-5 laps in once the tires were warmed up I started to push the car and was disappointed with how the car felt. I got back to the pits and could tell from the short 20 min session that my tire wear was not looking good pointing to a poor alignment. I got the track alignment with no other changes, hit the track again a few week later and it felt like it was a completely different car, I was very impressed with the cars stability after the alignment was fixed.
Make sure the dealer takes their time when doing the alignment and gets the specs as close as they can, my local dealer cannot do that for some reason. Luckily I found a shop that will take their time and get them spot on.
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle
mblum is offline   Reply With Quote
Old 05-07-2019, 05:29 PM   #5
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Because I want the dealer to do it next week under warranty.
Reason I wanted to get the independent numbers is because I didn't want the dealer to give me the run around and saying the car feels OK so no reason to put it on the rack.
Old 05-07-2019, 05:32 PM   #6
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Are any of the adjustment nuts and bolts Torque to yield?
Old 05-21-2019, 09:58 AM   #7
C Man
Drives: 2018 White Convertible Camaro ZL1
So alignment is under warranty? Were you able to confirm that?
White 2018 Camaro A10 Convertible ZL1
C Man is offline   Reply With Quote
Old 05-21-2019, 02:25 PM   #8
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Factory alignment is warrantied up to 7,500 miles - that's straight from the dealer that I paid $400+ to align mine at 8,700 miles....
Old 05-21-2019, 04:31 PM   #9
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Just came home, Got my mine done at the dealer, 2900 miles no charge.
Now my readings are PERFECT!!!
Old 05-21-2019, 04:58 PM   #10
kwav8r
Flyin NOE
Rock on!
Old 05-21-2019, 05:46 PM   #11
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
I took my 18 Z to the dealership twice for suspected poor alignment, snd they said alignment was "spot on"!
I finally broke down and took it to the best shop around...my buddy just laughed...the front and rear were waaay off from factory specs, and since I don't track the car we went with a Street alignment...the car has a true contact patch, handles beautifully, and has no extreme tire wear.
Intimidator is offline   Reply With Quote
Old 05-21-2019, 09:49 PM   #12
mblum
Did correcting the alignment fix the driving issues you mentioned in the first post?
Old 05-21-2019, 10:12 PM   #13
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Too many cars on the road on the way home to test. I'll advise in a day or 2!
Old 05-21-2019, 10:20 PM   #14
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Here is my corrected sheet from today.
