Old 05-07-2019, 06:15 AM   #1
KeithBridges
Drives: 2013 ZL1
A10 shudder?
I have a 2019 ZL1 A10. I know this discussion is all related to the A 8 but has anyone experienced the same shudder in the A10? I’ve been experiencing the same exact issues with my A10. I noticed it the day I drove it off the lot. Brought it back twice and they can’t find any issues. Told me to just drive it more that’s it’s probably just from sitting in one spot too long and the tires developed “flat spots” due to the cold weather. Well I’m in South Louisiana, the temperature hasn’t been below 50 since I drove it home and it’s been 85-90 degrees for the last 3 weeks. Still have the same issues.
KeithBridges is offline   Reply With Quote
Old 05-07-2019, 07:06 AM   #2
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
I am in Miami and have not experienced that... yet.
viurniel is offline   Reply With Quote
Old 05-07-2019, 07:18 AM   #3
SliChillax
SliChillax's Avatar
Drives: Camaro ZL1 A10, F-Type R, RR Sport
I only experience jerky-ness when I go from D to R or P, it's a rough transition.
SliChillax is offline   Reply With Quote
Old 05-07-2019, 07:36 AM   #4
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
That shouldn't happen since we don't use AFM in the LT4 Camaros.
7WSM is offline   Reply With Quote
Old 05-07-2019, 07:58 AM   #5
harner
harner's Avatar
Drives: 2018 ZL1 A10
Haven't heard of this shudder issue. Do not let GM push you off on the issue. Try to replicate the issue and take the service manager for a ride.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
Old 05-07-2019, 09:24 AM   #6
SSport16
SSport16's Avatar
You should have this checked out, I had it in my SS with an A8, once they reprogrammed the TCM it went away, but it gets worse if you leave it from my experience.
Old 05-07-2019, 10:03 AM   #7
DangerZL1
Drives: 2023 Black ZL1 Auto
You're going to have to push the dealer to work with you. I'd have the dealer road force balance the tires to rule them out, or do a temp swap if possible to another set. Vibration or shudder problems aren't normal for the A10 ZL1.
Old 05-08-2019, 09:20 PM   #8
KeithBridges
Drives: 2013 ZL1
Dealer done a road balance test and they said it wasn’t bad enough for Chevrolet to do anything. The service manager rode with me and he felt it also and then drove it and said it was more noticeable but still couldn’t do anything until it gets worse. They basically said continue to drive it until it gets worse. That was about a month ago and it’s not getting any worse but it’s not better either. On a side note I have changed the rear diff fluid and oil twice with the correct fluids bought at the dealership.
Old 05-08-2019, 10:26 PM   #9
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Nothing here.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 05-09-2019, 08:32 AM   #10
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
There were reports of cars that were overfilled on the trans, but those were early 2017s, not a 2019..
https://www.camaro6.com/forums/showthread.php?p=9951480
