05-06-2019, 01:25 PM | #1 |
Drives: 2010 camaro Join Date: Dec 2017
Why did the clamp get loose?
I was driving on the roadcourse and this clamp got loose. My first track day it got loose and this is the second time it got loose. And yes I made sure it was tight beforehand. Are the clamps a one time use or something?
05-06-2019, 01:56 PM | #2 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Im gonna assume your talking about those intake clamps since you didnt specify but thats probably something you want to take up with the manufacturer of that kit. Maybe they have large tolerances
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
05-06-2019, 03:00 PM | #3 |
Drives: 2018 Summit white 2SS 1LE Join Date: Nov 2016
it was probably junk to begin with or over tightened. go to the auto or hardware store and get a better quality one for a few bucks.
05-06-2019, 03:31 PM | #4 |
Drives: Black Join Date: Jan 2017
One side is attached to the chassis, one side is attached to the engine. Your engine might be moving more than than the flex coupling has play in it.
05-06-2019, 10:19 PM | #5 |
Drives: 2017 SS 6sp Join Date: Jun 2014
05-08-2019, 09:32 AM | #6 | |
Drives: 2018 Black 2SS Convertible RedLine Join Date: Apr 2018
05-08-2019, 07:00 PM | #7 |
thanks for the help fellas!
05-12-2019, 12:38 AM | #8 |
damn gremlins.
05-16-2019, 06:49 PM | #9 |
One of the clamps from rotofab is smaller than the other. Did you put them in the correct locations?
