Old 05-04-2019, 09:18 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
adding resonators to exhaust. think they will fit
i want to add these https://www.summitracing.com/parts/xfo-ct04-14s side by side in the transmission tunnel. i have 3" exhaust these are 4" outside. think they will fit?
Old 05-04-2019, 10:00 PM   #2
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
I'd doubt it. Maybe if they were staggered. I have the off the shelf type magnaflo 4"round case. I think I tried to put them in that area too but couldn't pull it off. But I can't custom bend stuff either. Maybe a shop could do it
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 05-04-2019, 10:04 PM   #3
JCunningham
Drives: 2017 2SS M6
that sucks. good thing i can return them.
Old 05-04-2019, 10:13 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Sounds similar in size to the resonators that AWE offers in their dual 3” system. There is very little room between them, I’d guess 1/8”. But, they fit and do not rattle against each other. Hopefully that helps.
Old 05-04-2019, 10:20 PM   #5
JCunningham
Drives: 2017 2SS M6
so you have done this?
Old 05-04-2019, 10:40 PM   #6
Joshinator99
Moderator
I technically have the AWE Resonated, Touring, Catback with Performance Link Pipes. The mid-pipes have dual 3” resonators already welded in by AWE. They fit up in the “tunnel”. I’d guess the OD of the resonators are 4”. As I mentioned, it’s a close fit, but it works fine.
Old 05-04-2019, 10:42 PM   #7
JCunningham
Drives: 2017 2SS M6
thanks
probably no pics?
Old 05-04-2019, 10:45 PM   #8
Joshinator99
Moderator
thanks
probably no pics?
Good God, you’re needier than my girlfriend... Kidding! Here you go.
Old 05-04-2019, 10:50 PM   #9
JCunningham
Drives: 2017 2SS M6
now i need you to go out and measure them and post pics of your girlfriend
Old 05-04-2019, 10:51 PM   #10
JCunningham
Drives: 2017 2SS M6
sweet they look about the same nice welds
Old 05-04-2019, 10:54 PM   #11
Joshinator99
Moderator
LMAO, her “resonators” are bigger than 4” OD, FYI.
Old 05-05-2019, 10:16 PM   #12
JCunningham
Drives: 2017 2SS M6
just a vid of my exhaust befor the flowmaster AT NPP mufflers
Old 05-08-2019, 05:59 PM   #13
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Hey JC. Is your ARH Long setup considered a 3in system? Where it slips over the stock NPP pipes that you cut. Does the ARH reduce down to 2.75?
I have the ARH Full System with their dual tip mufflers and because of a bit more drone than I like was trying to figure a way to connect it to my NPP. What has me wondering though is if my system is a full 3in all the way back to where the NPP pipes would meet. Maybe I should go measure it. lol.
Any drone with that setup?
Dysan911 is offline   Reply With Quote
Old 05-09-2019, 02:53 AM   #14
JCunningham
Drives: 2017 2SS M6
it slips over the NPP and the Flowmaster American Thunder mufflers is 3" inlet to slip over the 2.75". they were the same size pipe and i had to have the mufflers welded to the ARH exhaust. Yes the ARH was 3" inside diameter all the way.
