Old 05-04-2019, 08:51 AM   #1
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Elsd software upgrade?
Anyone try the performance update for Elsd software? And what did you pay? My dealer wanted $350 plus $150 labor..
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 05-04-2019, 10:00 AM   #2
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
It should be $350 without a labor charge. It even says that in the “install instructions” they either didn’t read it or are trying to screw you out of money.
IG: @NC_M1SS1LE
Old 05-04-2019, 11:21 AM   #3
pbsinternet1le
Did you get it? And if so can you please explain if you can tell a difference?
2017 1LE Hyper Blue
Old 05-04-2019, 12:15 PM   #4
appleman22
Drives: 2017 1ss 1le
unless you are a hardcore auto crosser, you will never feel the difference.
appleman22 is offline   Reply With Quote
Old 05-04-2019, 12:34 PM   #5
pbsinternet1le
That is what i have heard but it is being advertised as better turn in for track and autocross.. have you tried it?
2017 1LE Hyper Blue
Old 05-04-2019, 02:56 PM   #6
JonD
JonD's Avatar
Drives: 2018 SS 1LE
I’ve been told eLSD engages faster out of a corner. Pretty sure if it were a free update everyone would do it
The ONE a person who chimed in on my post that actually did it says you won’t notice a difference on the street... i might do it just to see. Probably a waste of $350 bucks
The road course guys also say they didn’t notice anything so the assumption is that a pro driver dropped lap time after learning the new eLSD. Again not something most will notice
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 05-04-2019, 04:21 PM   #7
pbsinternet1le
Anyone that actually has the upgrade?
2017 1LE Hyper Blue
Old 05-04-2019, 05:08 PM   #8
pbsinternet1le
From what i understand it only works when all nannies are off... I don't care about street .. asking if anyone has used it on a roadcourse??? and if so does it work?
2017 1LE Hyper Blue
Old 05-04-2019, 05:46 PM   #9
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Didn’t ask if you cared about the street as I drive with nannies off all the time. Trying to save you the bullshit you’re getting. You aren’t going to noticed a damn thing unless your timing your road course laps and you better be one hell of a driver pushing limits but good luck getting the validity you’re searching for
Old 05-04-2019, 06:08 PM   #10
pbsinternet1le
your response says you won't notice on the street. My question is has anyone used it?? don't be a d...jon
2017 1LE Hyper Blue
Old 05-04-2019, 06:18 PM   #11
JonD
JonD's Avatar
Drives: 2018 SS 1LE
You are the reason why people stop responding when the questions have already been asked. You are also the reason people say use the search function.
I gave you info based on prior road course peoples answer to your question AND added the street comment to anyone else looking because it’s something that comes up so was trying to be helpful...
You should stop being a such a D yourself
Old 05-04-2019, 06:27 PM   #12
pbsinternet1le
since you don't know the answer to the question why do you feel a need to respond? please stop. Not sure what you are trying to prove?
2017 1LE Hyper Blue
Old 05-04-2019, 06:29 PM   #13
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Here you go, I’ll help you out since you still can’t accept that I was trying to help...
https://www.camaro6.com/forums/showp...0&postcount=27
Old 05-04-2019, 08:20 PM   #14
MatthewAMEL
MatthewAMEL's Avatar
I have it on my 1LE.
I installed in December and have run a couple of track events and 6 AutoX events.
1 - No difference on street
2 - No difference on Track
3 - marked difference in AutoX as long as you 'turn it on'. On the Kart track at Daytona, (I use this because it doesn't change from event to event), it's much quicker to let you have 'all the power'. It does not pull power on corner exit like PTM used to.
I have a regular co-driver and he noticed the difference in the 1st event.
YMMV
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
