![]() Drives: 2016 Camaro SS Join Date: Dec 2016
Procharger and Meth
For those using meth with their Prochargers, how did you installed the nozzle when using the upper rubber pipe?
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
subbed for reference
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
Pretty sure the nozzle is threaded and there is a nut you tighten from the inside to draw it tight to the elbow. Probably. Good idea to lock-tite it with the blue stuff so it doesn't come loose and end up in the motor.
![]() Drives: DZ Join Date: Aug 2018
On my car I am using twin meth nozzles, just drilled two holes in the rubber elbow that is on the throttle body.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
The nozzles install about 2" before the entrance to the TB. As said holes are drilled into the inlet tube and then the nozzles are pushed in and threaded from the inside.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
