04-30-2019, 07:03 PM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
How to remove water spots from clear bra
One of my cars is parked under my AC air handler which drips water. Well, it appears to be leaving spots in the clear bra. What will remove them without damaging the clear bra?
Now I leave a towel on the hood, so I have the fix, but how to get it back looking like new?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
04-30-2019, 07:13 PM | #2 |
Drives: None at the moment Join Date: May 2018
https://www.amazon.com/Plexus-20207-...62212771&psc=1
This is what was recommended to me by my clear bra installer. Its gods gift to them. Worked to clean, shine and protect the bra. Its like unicorn juice. |
04-30-2019, 08:31 PM | #3 |
Thank you Al Oppenheiser!
I’ve used Carpro water spot remover on my car, both the coated PPF and coated paint with success. It’s citric acid based.
https://www.autogeek.net/carpro-spot...r-spot-remover CLR will work too if they’re really bad. https://www.walmart.com/ip/CLR-Calci...ottle/14574716 |
05-01-2019, 05:17 AM | #4 |
Thanks for the replies. I ordered all of them. Hopefully it isn't permanently damaged.
05-03-2019, 02:33 AM | #5 |
Drives: 2016 camaro Join Date: Mar 2018
You can also try the Xpel PPF cleaner.
05-03-2019, 07:44 AM | #6 |
So far i have tried Carpro, 2 different brands of detail spray, Hybrid V7, and the PPF cleaner the installer had given me and NO luck with any. My order for Plexus should be arriving tomorrow. Hopefully that does the trick.
05-03-2019, 08:41 AM | #7 |
"Camaro Style"
Drives: 2011 2SS/RS A6 & 2018 ZL1 Join Date: May 2011
I have used a 1 to 1 solution of vinegar and water to remove nasty water spots.
05-04-2019, 04:45 AM | #8 | |
If nothing is working at all then perhaps the PPF may be etched... Last edited by Gunkk; 05-04-2019 at 05:08 AM. |
05-04-2019, 03:07 PM | #9 |
Update, tried the Plexus and tried 50/50 Vinegar water mix and tried straight vinegar and only slight improvement. When the wife gets home I will ask where she hid the CLR and try that. Was just waiting to try the what I think to be the harshest last.
05-04-2019, 03:38 PM | #10 |
Drives: Caddilac ATS Join Date: Apr 2019
Try citric acid instead of vinegars it's less harsh on plastic
You can also claybar a clear bra. J. |
05-04-2019, 06:00 PM | #11 |
Guess I can try that too. Between the water spots and the Love Bugs I have to clean it twice a day
05-05-2019, 09:14 AM | #12 |
Well, didn't have any CLR, but did have lime away. It worked better but some still remain. Guess it's etched in. Only thing I forgot was to clay like someone mentioned.
