Old 04-30-2019, 09:52 AM   #1
Twinzero
Twinzero's Avatar
Drives: 2018 Camaro ZL1 A10 HBM
Ceramic Coating + Hard Water
I had my ZL1 partially PPF wrapped and fully ceramic coated this weekend. How do you handle rinsing off your ceramic coat with hard water? We have it bad here in central Texas. I have seen 3 solutions:
1) Get a DI Water System specifically for washing the car. This is an expensive option.
2) Use hard water in the shade, blow dry off, and hope you get every drop before it dries.
3) Take to the local hand car wash place and use their pressure wash and spot free rinse.
Is #1 worth the price premium? How effective are these DI systems and does anyone have a recommendation?
The shop that did my coating threw in some great glamour shots as well.
Twinzero is offline   Reply With Quote
Old 04-30-2019, 09:57 AM   #2
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
If you have a quality ceramic coating, all you will need is a stout air dryer. You may need a small microfiber towel for small water drips.
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 04-30-2019, 10:01 AM   #3
Burly
Burly's Avatar
The CR Spotless DIC-20 works for me. I only use for the final rinse and that final rinse should be a long one. So long I usually go around the car 3-4 times to make sure I've replaced the hard water with the DI water. It's expensive but with my hard water, it's the only thing I've found that works.
The problem is drying. I use the electric blower to know off the majority of water and then with VERY lightly dry with a towel. I've been using Beadmaker to spritz the towel and surface as well.
Burly is offline   Reply With Quote
Old 04-30-2019, 10:25 AM   #4
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
I live in Ohio, out in the Country with Well Water.
My outdoor hoses are straight from the well...only inside water is treated.
We have no issue with water spots...we wash the cars early in the am or late pm...we blow dry the cars, and immediately wipe down.
We use Adams Ceramic Boost, H2O, and Jax Wax Ceramic detailer, to eliminate spotting and keeping the surface slick and shiney!
Intimidator is offline   Reply With Quote
Old 04-30-2019, 10:39 AM   #5
Sooner Cole
These are expensive, but work great!
https://www.amazon.com/dp/B0711L4Y6F..._t1_B0002SPCGC
19 ZL1-1LE A10
Old 04-30-2019, 10:41 AM   #6
Twinzero
Twinzero's Avatar
Are any of you using special blowers for cars or standard leaf blowers? I've got a pretty dinky battery powered blower that has an extremely narrow jet of air which works fine on the driveway, but doesn't seem to be well suited for drying off the car in a decent length of time...
EDIT: Saw your post after submitting my reply Sooner. That looks like a great option but it's pricey!
Old 04-30-2019, 10:51 AM   #7
wnyzl11le
wnyzl11le's Avatar
Drives: 2019 zl1 1le
I use this to blow the car off.
https://www.griotsgarage.com/product...rPicks&from=fn
2018 GMC Denali 6.2L
2019 Camaro ZL1 1LE 6 speed Riverside Blue 1LE NAV PDR. PPF entire car
wnyzl11le is offline   Reply With Quote
Old 04-30-2019, 10:54 AM   #8
Brettmess24
Drives: 17 C7 GS WGG
I use the McKee’s dryer and follow up with an SIo2 spray from Wolfgang or use Kenotek.
Brettmess24 is offline   Reply With Quote
Old 04-30-2019, 10:56 AM   #9
wnyzl11le
wnyzl11le's Avatar
Also OP killer shots of your car it looks great!!
Old 04-30-2019, 11:34 AM   #10
Intimidator
I use my gas STIHL BG86C-E Leaf blower! Lol
Old 04-30-2019, 11:56 AM   #11
RobbyRocketz
Drives: 2016 Chevy Camaro SS Mosaic Black
Big Boi Blower heated air is nice, and it pushes air like crazy.
RobbyRocketz is offline   Reply With Quote
Old 04-30-2019, 12:38 PM   #12
Badmojo
aka BeastZL1
Badmojo's Avatar
This.....
Sent from my iPhone using Tapatalk Pro
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-30-2019, 12:51 PM   #13
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I have VERY hard water here in FL.
You don't have a choice, you need to get a DI system to rinse the car.
I have the metrovac 8hp, works great.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 04-30-2019, 01:27 PM   #14
IneedAZ
IneedAZ's Avatar
How do you get the water spots off of the paint protection without discoloring it? I have the protection film on both my Zl1 and my Charger. Zl1 thankfully is in good shape, but i park my Charger under my air handler and it drips on the on hood and has water spots in the protection film.
