Old 04-25-2019, 08:05 PM   #1
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
Turbo "momentum" between M6 shifts
Hi guys I looked around to try and better educate my self so I could sound a little informed maybe get farther along.. M6 with a tune. I would say its a 5 out of 6 on the, ahemm, race chip scale. Lets assume its a moderately high boost increase, everything else factory.
So I find when I am pushing hard really the only shift point of concern, from 1-2 that the engine continues to "spin up" between shifts. What kind of process is it that causes what I am assuming is the air charge to keep the engine winding while the throttle plate is closing. Which I am picturing like the good old spring loaded slam shut.
Could it be the return rate of the throttle plate is slower, I wonder? Maybe that's programed to close slowly under high boost so as not to not over charge the intake and cause bad things.
So my question is more than just throw parts at it (BOV), which I will gladly do but need a code free solution. People must have dealt with this and not ended up code bound. BTW There happens to be a more definite swoosh sound in these conditions at throttle let off.
It might not be as apparent on AT cars. But try stopping your car at this similar juncture.
Thank you in advance for educated ideas. Or pointers to other turbo forums.
G.
wookwook is offline   Reply With Quote
Old 04-26-2019, 10:42 AM   #2
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
Have you ever tried NLS (no lift shifting)?
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq
ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator
Adp2017 is offline   Reply With Quote
Old 04-26-2019, 11:38 AM   #3
wookwook
wookwook's Avatar
NO!!!!!!??
Does the LS support that?
I have by curiosity tested changing gears on cruise control and it just complies with no throttle work.
Old 04-26-2019, 04:15 PM   #4
wookwook
wookwook's Avatar
I don't think mine has it. :(
checking resources..... I think its a premium pkg feature on other years.
2018 only has the "LS" as far as I know.
Old 04-26-2019, 04:43 PM   #5
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
It probably does have it. It's a pita to get it to do it though. Pedal to the floor, shift after 6000 RPM, don't hesitate, don't lift up. Almost impossible to get your brain to do it.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 04-26-2019, 07:11 PM   #6
wookwook
wookwook's Avatar
Ahh. But at 6k what is the point? My sweet spot is way before 6k, even to hit 3rd before 60 mph.
And exactly what is a JacFab Boost-O-Lator High Performance Re-Circulation Valve? Is that on the intake side or where? Any BOV (recirculating) obviously it seems will need coding work.
Would be nice to have ala carte code tweakers (in-a-box), Anyone? I bet there's a market.
Old 04-26-2019, 09:16 PM   #7
Start The Machine
When you're tuned, the drop off is at 5500-6000 RPM. Huge difference. When you get NLS right it's awesome.
The recirculation valve is the internal bypass valve on the actual turbo. The stock valve leaks boost. The JacFab/BNR valve is sealed air tight and doesn't leak any boost. It doesn't need tuning to work. But when tuning with it, its incredible.
Old 04-26-2019, 10:54 PM   #8
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
My LS has the NLS. It's freaking awesome. It actually works at 5000 RPM. Makes the shift so quicker and the feeling so awesome. Never really tested it to its max potential as it is illegal on the roads, but I hope I'll have the chance to do it one day!
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 04-27-2019, 01:35 AM   #9
Start The Machine
^ what he said.
Old 04-27-2019, 07:58 AM   #10
wookwook
wookwook's Avatar
cool. and i re-read the thread with the topic, and I am getting educated. thanks everyone.
Old 04-29-2019, 08:54 AM   #11
zts1986
Drives: 2019 Chevrolet Camaro 1LT 2.0T
The thought of this terrifies me!
zts1986 is offline   Reply With Quote
Old 04-29-2019, 12:07 PM   #12
Start The Machine
Exactly. You're going to end up in someone's front lawn.
Old 04-30-2019, 07:23 PM   #13
wookwook
wookwook's Avatar
Found the NLS info its 4400 rpm for the ltg
https://www.camaro6.com/forums/showthread.php?t=513327
Old 04-30-2019, 09:32 PM   #14
zts1986
My goodness I have got to try this.
