Old 04-25-2019, 04:14 PM   #1
TheRedhead
TheRedhead's Avatar
Drives: 2018 Red Hot ZL1 1LE
I knew this would happen:
Transport guy was having a tough time with the car...and this is the aftermath.
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built!
TheRedhead is offline   Reply With Quote
Old 04-25-2019, 04:20 PM   #2
esm
esm's Avatar
Drives: 2019 ZL1
I put this on mine, I don't worry about scrapes anymore.
https://wildhammermotorsports.com/ca...e-kit-protekt/
2019 Black ZL1 - A10
esm is offline   Reply With Quote
Old 04-25-2019, 04:27 PM   #3
TheRedhead
TheRedhead's Avatar
I may definitely look into it.
I don't scrape often, but I knew loading it into the hauler was going to be fun.
Built!
Old 04-25-2019, 05:58 PM   #4
Fredtp
Fredtp's Avatar
Drives: 2019 ZL1 A10 Black Mosaic
Did you put your spring blocks in that came with the car?
Fredtp is offline   Reply With Quote
Old 04-25-2019, 05:59 PM   #5
TheRedhead
TheRedhead's Avatar
1LE. Doesn't come with them.
Built!
Old 04-25-2019, 08:33 PM   #6
Getnlwr
Drives: '21 ZL1 A10 '08 SRT10
How hard are the spring blocks to get in anyway?
Getnlwr is offline   Reply With Quote
Old 04-25-2019, 08:49 PM   #7
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
That is like a $30 dollar part though, no worries.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 04-25-2019, 08:52 PM   #8
19Nasty1le
Craig
19Nasty1le's Avatar
Mine came delivered like that from factory, not as bad but at least it can’t be seen. Still a pissoff
19Nasty1le is offline   Reply With Quote
Old 04-26-2019, 12:53 AM   #9
Pepsiguru
Drives: 2018 ZL1 A10
This looks very interesting.
Very kool . . I scrape everyday coming out of my driveway.
Good to know there is a fix
Pepsiguru is offline   Reply With Quote
Old 04-26-2019, 06:45 AM   #10
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Those air deflectors are pretty cheap. I replaced mine a while back ago
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 04-26-2019, 07:06 AM   #11
HDRDTD
I get a kick out of products like this.
Back when the 5th gen ZL1 came out, IIRC ZL1Addons came out with a washer kit for the front spoiler that was meant to use some very nice machined and countersunk washers as a wear surface.
Yes they give you a wear surface, but at the same time, they reduce your ground clearance that was the cause of th escrapes to begin with. ??
Old 04-26-2019, 09:58 AM   #12
ICTsccaCamaro
Drives: 2018 ZL1 1LE
I would assume the front splitter is more than $30.
ICTsccaCamaro is offline   Reply With Quote
Old 04-26-2019, 11:28 AM   #13
Alain
Alain's Avatar
I was thinking the same exact thing. Adding that skid plate to the very front of the splitter will reduce ground clearance which will cause you to scrape more frequently. The added lack of ground clearance can cause the spliter/bumper to flex or get hung up on the pavement (if you're backing the car) causing damage to the mounting surfaces.
I think he was referring to the rubber air deflectors.
2018 ZL1 1LE/Red hot
Old 04-26-2019, 11:29 AM   #14
Alain
Alain's Avatar
At least it's not visible and it's not a metal part that will rust.
I would still be annoyed about it like you are.
