Old 04-24-2019, 07:37 PM   #1
Homeless Junkie
Homeless Junkie's Avatar
Drives: around in circles few days a month
A bad day..
So I took my car to get the 1500 mile service today. I’ve been putting it off but not driving it. I pick up the car from my mechanic and about five minutes later the tpms says I got 21 psi left in the driver front tire. I think damn picked up a nail. Get home and look, found a plug! WTF?
The dealer really sold me a tire with a plug? Wouldn’t the plug be worn down after a 1000 miles? I can’t imagine why the mechanic wouldn’t say something if it’s his fault. What do you guys think?
The last picture is my fender after hitting a electric box in the garage pulling it back into the garage. All this and I have a performance driving course at Somona Friday. Guess I’ll lose that $500.
Homeless Junkie is offline   Reply With Quote
Old 04-24-2019, 07:48 PM   #2
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Just looking at the picture, that doesn’t look like a plug...Also looks like you may have a cut to the side wall, I’d be concerned about that.
Old 04-24-2019, 07:54 PM   #3
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
That really sucks, but why miss your track event? Is the fender interfering with tire? If not see if you can order a new 3R from tire rack tonight, they often deliver in one day in CA so you could have it by Friday. Then you can make the event and fix fender next week
Your tire reminds me of the dealer issue I had, Keyes Chevy in Van Nuys tore the bead on one of my 1600 street miles GY 3Rs removing to mount PS4Ss and denied they did it. That plug looks bad, shouldn't be so big or visible, and maybe shouldn't be plugged so close to shoulder on an R comp.
SFV1LE is offline   Reply With Quote
Old 04-24-2019, 07:56 PM   #4
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
When you zoom in on the picture, it almost looks like a metal rod is protruding from the sidewall towards the center of the tire. Maybe it's just the way it looked at the time. Also, do you have any other pics the damage from the electric box? The one that is there is a little deceiving and indistinguishable. Regardless, a bad day for sure. Sorry brother
SHE'Z 18 is offline   Reply With Quote
Old 04-24-2019, 08:04 PM   #5
Homeless Junkie
Thanks for the advice and kind words guys. My mechanic thinks he may be able to get tires tomorrow.
Shez18, the fender is just snuffed. I got some of it off with polish!
Old 04-24-2019, 08:05 PM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
That tire should not have been repaired. That is no-patch area, ie tire is scrap.
Hard to tell, but looks like sidewall is cracked ?
Turns the lights on or flash on and retake the photos.
2019 and folks still taking potato photos.
ing for grip.
http://www.motorsportsne.com/
Old 04-24-2019, 08:08 PM   #7
Homeless Junkie
Potatoes? The flash was on
Old 04-25-2019, 11:57 AM   #8
rickybobby
Drives: BMW M3, ZL1 1LE
Wait so you brought your car in for service and they damaged and plugged your tire without telling you?
Was this a dealership?
rickybobby is offline   Reply With Quote
Old 04-25-2019, 12:07 PM   #9
staples87
Drives: 2017 Camaro ZL1
If that is a plug, then it's an outside one at that (meaning they didn't take it off the rim and patch it from the inside).
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 04-25-2019, 12:14 PM   #10
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yea i hit a potholes a couple weeks ago and curbed my wheel and cut my sidewaell in my tire had to replace tire and fix wheel $500 down shit sucks
Old 04-25-2019, 02:20 PM   #11
Homeless Junkie
OK so I found out that's not a patch.. It's the run flat goo. I must of hit something a few minutes after I left the gas station which was 10 min after i left my mechanic.
I'm sure it wasn't the mechanic. No dealership! Not after they delivered my car with the radio and bass all the way up! I timed the leak when i go home. In ten minutes the PSI went from 30 to 23. The mechanic and I BSed for at least 20 minutes. He's got a Camaro too. I went to the gas station, filled up and then about ten minutes later the TPMS alerted 24 psi.
It's just a bit of bad luck is all. Too bad that $500 for the course tomorrow is nonrefundable
Old 04-25-2019, 02:21 PM   #12
Homeless Junkie
The second time I read this it hit me. I do think I hit something on the way outta the gas station. Thanks for posting!
Old 04-25-2019, 02:36 PM   #13
full*throttle*therapy
Drives: '18 RH ZL1 1LE
ZL1 1LE's don't have run-flats.
full*throttle*therapy is offline   Reply With Quote
Old 04-25-2019, 02:39 PM   #14
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
ZL1 in general does not have run flats, no?
gotswap is offline   Reply With Quote
