![]() Drives: 2019 ZL1 1LE Join Date: Apr 2019
2019 ZL1 1LE with 345's
I know there is no need for 345/30/19 on the Zl1 1LE but I just got my 2019 ZL1 1LE and I love the 3R for track but take a bit to warm up on street and will be switching to R888R as its hot where I live and hardly ever rains.
My buddy has (2) 345/30/19 R888R 'S and I can get them for 1/2 price so wondering if it will fit. It looks like it will but would like confirmation. I understand a bit of handling may be effected due to the wider tire but I will put the 3R on when I track. The R888R setup is for Street and actually my daily. I know they only last 8k if that but have no issue with that. |
![]() Drives: 2018 ZL1 1LE Join Date: Dec 2016
Drives: 2018 ZL1 1LE Join Date: Jun 2012
They should fit fine there seems to be alot of room on the inside of the rear wheel and tire, I was planning on running the 355/30r19 Kumho Viper ACR rear tires on mine in the future.
#4 | |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
Here are some information
MPSS 335 fits?
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
He is talking about 345/30. With 335 you have to reroute the harness on the rear driver side.
Soleil
#7 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
I bet that these would fit. I had my tires off recently and there's plenty of room in back for 20mm more. Post up pics after the install.
Check it out...https://www.camaro6.com/forums/showthread.php?t=552714 |
#8 |
#9 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Nov 2019
355/30R19 fit?
#10 |
And spacers
As well did you run with any wheel spacers.. Like 3 or5 mm thickness
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I did 325/30/20. A 355/30/19 will be about .3” shorter but 1.2” wider. Someone on the site has done a 345/30/19 without issues. That might be the max. I won’t go any wider than I am now tho but that’s due to height.
