Old 04-22-2019, 11:58 PM   #1
squish72
Drives: 2016 2SS 8AT
Need tire size help
I've ordered new mrr 755s for my 2ss and went with 19s (10x19,11x19) now I need some help
I would like ps4s
stock is
245/40-20 = 27.7x9.6
275/35-20 = 27.6x10.8
265/40-19 = 27.3x10.4
295/35-19 = 27.1x11.6
275/35-19 = 26.6x10.8
325/30-19 = 26.7x12.8
It's not going to be a track car so I'm not concerned with lateral traction just straight line traction
Car has a few mods and that's why I was wanting more width but I understand too wide can actually be a negative because of surface area spreading out the weight giving less pressure pushing on the pavement. Also when dia. drops so does forward traction.
Last edited by squish72; 04-23-2019 at 12:48 PM. Reason: added stock size and widths
squish72 is offline   Reply With Quote
Old 04-23-2019, 05:00 AM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
2nd option. But it will increase the wheel well gap slightly.
Old 04-23-2019, 11:19 AM   #3
squish72
Can you elaborate why?
I also added the stock sizes and added the tire widths to the original post
Old 04-24-2019, 09:36 AM   #4
Markoz28
Drives: 18 ZL1 nightfall grey A10
The second option is slightly shorter than stock which will give a bit more gap between tire and fender due to a decrease in tire height.
I would consider a 305/35/19 Nitto NT05. The hieght is close to stock and about 1.5” wider.
A shorter tire will decrease top end but will allow for quicker acceleration (mute point if you can’t grip). I prefer staying as tall as stock but as wide as possible.
Markoz28 is offline   Reply With Quote
Old 04-24-2019, 10:32 AM   #5
BradfordCamaro
SABIO
Looks like Option 2 became Option 3.
Sizing for Option 3 works. Wider and slightly smaller diameter.
I ran 275/35/19 square on 9.5" wide FS01's.
Car felt great and nimble. No issues with any of the nannies.
Going to slightly wider wheels would need slightly wider tire obviously.
Old 04-24-2019, 11:24 AM   #6
squish72
I agree a 305/35 would be perfect but nitto doesnt have a front tire that would match it. The closest is a 255 and I think that would be way to skinny for a 10" rim
I will add that I do drive the car almost daily (30 mile round trip) and do 500 mile trips almost once a month. Id love a drag radial for the back but with as much as I travel I think ill have to compromise the optimal grip for better wear
Old 04-25-2019, 08:08 PM   #7
CanyonCarver
Finding New Roads
CanyonCarver's Avatar
Drives: 2016 Camaro 1SS
If you daily drive the first thing to do is go square setup so you can rotate
the best setup imo is 285 35 on a 19 or 20 by 10"
CanyonCarver is offline   Reply With Quote
Old 04-25-2019, 11:26 PM   #8
squish72
I've got staggered wheels 10s and 11s
Old 05-02-2019, 09:25 AM   #9
squish72
Still unsure on what to do. I might be putting more thought then needs but when dropping that much coin on tires I wanna try and do it right the first time.
Old 05-02-2019, 12:38 PM   #10
Osbornsm
Drives: 2018 SS 1LE
Yup, over thinking it.
But PS4S are the best summer tire you can get.
Front wheel 10" = 285
Rear wheel 11" = 305
Those are the ideal widths for the wheel widths you mentioned.
The sidewall aspect ratio will be 35 or 40.
- I'm sure there's a calculator you can use
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 05-13-2019, 12:58 AM   #11
squish72
Question
Just wanted to update this for any future searches for people. Went with ps4s in 275/35r19 with a 10x19 et 23
325/30r19 with a 11x19 et 43
I haven't crawled under to visually see how close things are in the rear but just feeling with my hands there is a surprising amount of clearance still.
The sidewalls of the rears poke just a hair past the fender but the tread at the top of the tire is completely in the fender
Old 05-13-2019, 04:43 AM   #12
BradfordCamaro
SABIO
Looks really good.
Congratulations
Old 05-13-2019, 04:52 AM   #13
JeromeS13
Drives: 2017 1SS/1LE
Holy fender gap!
Old 05-13-2019, 05:10 AM   #14
Bluecyclone
Bluecyclone's Avatar
Drives: 2014 Cyclone mustang
MRR wheels
That is quite a gap, does this mean lowering springs needed? I just bought new wheels and was considering MRR M600's but found SVE GT7's the same design & weight in 19x10 @25lbs. A much better price, on sale @LMR. MRR M600 were $250 plus. It's pays to "Do it right the 1st. time and shop for the best price.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/
Bluecyclone is offline   Reply With Quote
