Old 04-22-2019, 11:43 AM   #1
chross12
chross12's Avatar
Drives: 2016 ss whipple,rotofab,A8,magride
A8-confusion.
I am going to be replacing the factory torque convertorand not sure which way to go? Also the stall speed is kinda confusing as well. I have never owned an auto before. Drag and daily driver is what i plan to do. Circle-d has a good reputation from what i can see. They are proud of their units.also what shifter? Thanks to all in advance.
chross12 is offline   Reply With Quote
Old 04-22-2019, 12:16 PM   #2
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
With all due respect you need to research on here a little bit because you have to tune the TCM when installing an aftermarket torque convertor. There are a few threads on here about it. Good luck with your modding.
dmcmahan60 is offline   Reply With Quote
Old 04-22-2019, 12:24 PM   #3
Umbriel
Drives: 2016 Camaro SS
If you don't have a cam just call Circle D and get a stock replacement, you won't have to tune anything. Unless you are wanting a higher stall for launching. Either way just ask Circle D what you need.
Umbriel is offline   Reply With Quote
Old 04-23-2019, 09:58 AM   #4
chross12
chross12's Avatar
I understand thank you for your guidance dmcmahan60 I will when I get some more time. I guess it goes back to how far to go; and still be able to daily drive it.
Old 05-01-2019, 03:39 AM   #5
UrMaster
UrMaster's Avatar
Drives: 2016 Hyper Blue Metallic 2SS
3c or 4c would be a great mix for a daily and some occasional drag racing.
UrMaster is offline   Reply With Quote
