Old 04-22-2019, 10:37 AM   #1
recontango
recontango's Avatar
Drives: 2018 ZR1
Second Oil Change - 1500 mi
I had the first (500 mile) oil change done at the dealership as the car was back in for some warranty work and they did it anyway. I am close to 1500 now and am considering doing the oil change myself.
My question: Would I be better off having the dealership doing the 1500 mi oil change so that it is on record with GM for warranty purposes? I don't really trust them with the lift and ensuring everything is done properly. Seems during the 500 mile change it was done ok, lift points look good underneath, oil level is good, just some sloppiness with filling the oil I needed to clean off the engine.
Appreciate the advise.
Current :2018 Black ZR1, 2018 Jeep Wrangler JL, 2017 Charger Daytona 5.7, 2017 Ram Power Wagon 6.4, 2018 Polaris RZR Turbo 4, 2018 XLR 5th Wheel Toy Hauler
Past: 2017 Challenger T/A 392, 2015 Challenger SRT 392, 2010 Camaro Synergy Green
recontango is offline   Reply With Quote
Old 04-22-2019, 10:46 AM   #2
ScatPack
ScatPack's Avatar
Drives: None at the moment
Complete waste of an oil change. I have bought several new performance cars since 2000. Not one has ever had an oil change before 5k miles. There is no need. They dont use special break-in oil anymore. Havent for years and years. Not only that, but the oil filter catches all the particles that the magnetic drain plug does not. This is a huge waste of your time and money. Not trying to be mean, but please you dont need to do another oil change.
ScatPack is offline   Reply With Quote
Old 04-22-2019, 10:55 AM   #3
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
I did a 500 mile and a 2,000 mile. My car has never been back to the dealership, even for TSB's. I'd rather just buy the parts and handle it myself.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 04-22-2019, 10:57 AM   #4
recontango
recontango's Avatar
Drives: 2018 ZR1
I understand where you are coming from, just trying to be sure I follow the GM recommended break in procedure so in case of a warranty claim they cant say I didn't...
Old 04-22-2019, 11:00 AM   #5
Old painless
Drives: 4 wheels and a motor
I will waste my money and gain peace of mind... every damn day of the week!
Old painless is offline   Reply With Quote
Old 04-22-2019, 11:04 AM   #6
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Same here, did one @ 500 and about to do one @ 1500. It is a 65k+ vehicle, if you are not willing to do a couple extra oil changes...….
Also going to do the rear end while I have it up in the air.
gotswap is offline   Reply With Quote
Old 04-22-2019, 11:11 AM   #7
wnyzl11le
wnyzl11le's Avatar
Drives: 2019 zl1 1le
Did both my 500/1500 mile at the dealer along with the rear diff flush and brake fluid flush from dot3 to dot4 for track use at 1500. Only reason it was all done at the dealer was warranty so GM can't come back and say...we have no record of this being done. I will be doing it myself from now on.
My 2 cents on the I never change my oil in my performance car because it doesn't have break in oil....I believe this is short sighted. All new motors will have metal particles in the oil during the first couple thousand miles. I would rather remove the particles replace the filter to ensure that something doesn't happen to the motor. I can tell you my rear diff oil and motor oil in the car had a good amount of metal in it. The Oil filter also had some metal in it.
2018 GMC Denali 6.2L
2019 Camaro ZL1 1LE 6 speed Riverside Blue 1LE NAV PDR. PPF entire car
wnyzl11le is offline   Reply With Quote
Old 04-22-2019, 11:16 AM   #8
Vigilante375
Drives: 2018 Camaro ZL1
Seeing as no where does it state that the vehicle has to be serviced at a dealership, then you are safe to do what you want to.
I changed by oil the first 500 and 1500 miles plus the diff fluid too. I've only let the dealership change the oil once (because we get 2 free oil changes) since I brought it in for a TSB and change out the tires.
Again, do what you want but GM can't deny the warranty just because you didn't get the oil changed at a dealership. Use the correct fluids and you'll be ok.
Old 04-22-2019, 11:23 AM   #9
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Keep records of oil and filter purchase.
The warranty concern is not needed.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 04-22-2019, 11:32 AM   #10
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
+1
Best if you buy your PF64 filter at the dealer. They actually are pretty comparable prices...the PF64 at the dealer is $4.30. Then Chevy knows you bought it. Take pictures of all of your receipts and products you bought. You can then store them all in one place.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 04-22-2019, 11:41 AM   #11
Fatty1707
Drives: 2019 ZL1 A10
" just some sloppiness with filling the oil I needed to clean off the engine"....
Of course there is! They cant and wont do anything right. Probably the oil drain plug and oil filter were over tightened too. Do it yourself. Just document and you will be fine.
Fatty1707 is offline   Reply With Quote
Old 04-22-2019, 11:51 AM   #12
greaser2
greaser2's Avatar
Drives: 2017 A10 ZL1 KG
Technically I agree except in the event there is engine issues, your gonna hear you didn’t change the oil per our schedule. Sorry!! And you can change your own oil, keep the records.
greaser2 is offline   Reply With Quote
Old 04-22-2019, 12:02 PM   #13
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
Agreed. An early oil change is cheap insurance.
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 04-22-2019, 01:21 PM   #14
Grumpy1
Grumpy1's Avatar
Tell them you want it done on a 4 post lift.
Grumpy1 is offline   Reply With Quote
