Old 04-20-2019, 02:50 PM   #1
seddon
seddon's Avatar
Drives: 2017 ZL1
Need a little
Not sure if I am posting in the right section. I just had headers and catback exhaust installed along with a tune. For some reason the coolant overtank will not go down. I know when the car is running the tank in filled and lower when car is off or cooled down. Pic was taken after the car cooled overnight. No over heating or anything. Any ideas, thanks in advance.
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
seddon is offline   Reply With Quote
Old 04-20-2019, 04:14 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Looks fine to me seddon! As long as coolant is in the bottom tank and you aren’t having any overheating issues, it should be good. Maybe some others will chime in but looks okay to me.
Old 04-21-2019, 04:42 AM   #3
MR2620
MR2620's Avatar
Drives: 2017 ZL1 - Hyper Blue
Mine has always looked the same. Top tank is full
Sent from my Pixel 2 XL using Tapatalk
MR2620 is offline   Reply With Quote
Old 04-21-2019, 06:31 AM   #4
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Upper coolant tank should always be full. Lower tank level will fluctuate. From owners manual:
Fill the surge tank top chamber
with the proper mixture to the
bottom of the fill neck. The top
chamber needs to be
completely full. Fill the surge
tank bottom chamber through
the service port to
approximately half.
Yours looks perfect!
breakskeet is offline   Reply With Quote
Old 04-22-2019, 03:51 PM   #5
seddon
seddon's Avatar
Drives: 2017 ZL1
chamber needs to be
the service port to
approximately half.
Is it also suppose to be filled when car is hot
Old 04-22-2019, 07:22 PM   #6
LT4Greg
LT4Greg's Avatar
Seddon, your Z is good to go. No worries!
Old 04-23-2019, 06:27 AM   #7
breakskeet
Kevin
breakskeet's Avatar
Yes.
Old 04-23-2019, 06:52 AM   #8
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
FWIW. I never knew what that lower tank was for and when I removed the coolant reservoir for a header install, I never filled the lower tank up at all. I did notice however that when my engine was warm from driving the coolant in the upper tank was completely full and when it cooled down the level would drop in the upper tank to about the fill line. I assumed this was normal operation until one day on here someone brought up a topic about the lower tank and how the manual states it should be half full. Ever since filling that half full my upper tank is always completely full no matter if the engine is hot, warm or cold overnight.
I suspect it's just an expansion tank and will draw in or push out fluid from the lower as needed to keep the top full 100% of the time.
Dysan911 is offline   Reply With Quote
Old 04-23-2019, 07:14 AM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
This is correct. The upper tank must always be full 100% of the time. The bottom tank is the one you add fluid to to keep it between the marks (~ 1/2 full) which of course are hard to see.
Great design from an engineering standpoint to ensure there's no air in the loop, but horrible from a owner/maintenance standpoint.
This manual page shows the purge procedure as well as a good graphic of what the two tanks should look like under normal conditions (hot or cold).
Gunkk is online now   Reply With Quote
Old 04-24-2019, 05:55 AM   #10
seddon
seddon's Avatar
Drives: 2017 ZL1
Thanks fellas sometimes i get paranoid, i guess its my ocd.
Old 04-24-2019, 11:03 AM   #11
breakskeet
Kevin
breakskeet's Avatar
Never hurts to ask man.
Old 04-24-2019, 01:02 PM   #12
LT4Greg
LT4Greg's Avatar
Glad we could help you seddon.
Old 04-24-2019, 03:33 PM   #13
Alain
Alain's Avatar
this is a great thread !!! never be afraid to ask questions man, it helps the rest of us who might have similar concerns.
By the way, I think all of us here suffer from OCD lolol.
2018 ZL1 1LE/Red hot
