Old 04-19-2019, 07:54 AM   #1
parish8
Drives: 17 SS a8
Massive a/w intercooled intake and interchiller data
G1pro is making this thing for me. Can’t wait to see it all finished up. That core is 10” wide, 17” long and 6” thick. I am going to use an “interchiller” which cools the intercooler fluid below freezing. Iat’s should be stupid low.
Old 04-19-2019, 08:56 AM   #2
laynlo15
Drives: 2022 Lt1 A10
Geeeeezzzzzz, that's big.
Old 04-22-2019, 08:30 AM   #3
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
That should get the job done! Cant wait to see it mounted in place.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 04-22-2019, 06:21 PM   #4
oldman
Drives: SS 6 speed of course
cool, literally cool... really cool, all his work is art... pure sex
Old 04-22-2019, 08:27 PM   #5
laynlo15
At your age Oldman? Haha. Me too.
Old 04-23-2019, 09:52 AM   #6
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Nice, but be aware anything lower than 45*F and the fuel spray from the injectors will form droplets and slow the burn, etc. Ideal is in the 50's.
Elite Engineering is offline   Reply With Quote
Old 04-23-2019, 10:11 AM   #7
parish8
Drives: 17 SS a8
Thanks. Now I have a target.
It has been pointed out to me by a couple of people those very short runners may hurt me a little. The cold air will help more than the runners hurt. It will be interesting to see where the numbers go. I may bolt the intake on without water and keep the air/air just to make a few dyno pulls and see what it does.
There should be some drive pressure savings once I remove my air/air. I am seeing a significant pressure drop across that unit. Then again maybe not since it will be pushing just as much or more air just at a lower pressure. Anyways, I will have lots of data to share eventually.
Old 04-23-2019, 10:51 AM   #8
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Yikes! Who says size doesn't matter
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 04-24-2019, 12:51 AM   #9
toohighpsi
Drives: 2015 C7 Z06 M7
What core is he using in there? Lots of work building a manifold like that so be sure that you're using the right components. (Note: Not sure what you're using, but Bell are not an effective A/W cooler)
Old 04-24-2019, 02:38 AM   #10
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Siiiccckkk
Old 04-24-2019, 06:38 AM   #11
parish8
Drives: 17 SS a8
Pretty sure it is a bell. How did you come to your conclusion?
Old 04-25-2019, 01:29 AM   #12
toohighpsi
We test lots of A/W coolers and the range of performance with aftermarket coolers is pretty big. The bell will provide a nice low pressure drop across the core, but their effectiveness (cooling ability) on the samples I've tested are on the lower end (about 60-65%)
Core size definitely impacts the effectiveness and it looks like you have a pretty big core, since it's nearly finished you'll have data from it soon!
Old 05-20-2019, 06:22 PM   #13
parish8
Drives: 17 SS a8
All finished up!
Old 05-20-2019, 06:30 PM   #14
ShizzySupra
Drives: 16' Camaro 2SS
Jeez thats crazy. Gonna have to cut hood for it but you are already yolo mode.
As far as IAT’s we worked with pro meth to do a quad nozzle setup through the lid of the Maggie 2300. Dropped temps 41 degrees over last year. Wont ever have to use an ice box, anything, etc and its back to back to back repeatable. Did you have meth on yours before?
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
