Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > USA - NY / NJ / PA
Old 04-18-2019, 01:43 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
anyone buying new tires. i need you bald ones. western ny
for winter storage. I dont need good tires just tires that hold air with no cords showing. Ill pick them up. 245s 275s
Old 07-21-2019, 02:32 AM   #2
JCunningham
Drives: 2017 2SS M6
still looking
Old 07-22-2019, 01:58 PM   #3
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
What did you do the last 2 winters?
Old 07-22-2019, 02:04 PM   #4
JCunningham
Drives: 2017 2SS M6
they have been on the car on carpet in a heated garage. wouldnt need to heat it if i had a set of ss tires
Old 07-22-2019, 02:20 PM   #5
TheRealJA105
Drives: 2013 C6Z06
Ah gotcha! I was just curious if you actually had any ill effects from cold winter storage, but I guess not since you are in a heated garage.
FYI I haven't had any issues with SC3s in unheated storage the last 2 winters.
Old 07-23-2019, 11:52 AM   #6
metros11
Drives: 2018 SS 1LE
May I ask why you would want them? Is it to prevent flat spotting? Because there are other ways.
metros11 is offline   Reply With Quote
Old 07-23-2019, 11:56 AM   #7
JCunningham
Drives: 2017 2SS M6
the tires i have now can crack if stored in temps below 20 deg. I have a extra set of rims that came with the car. i want to put the junk tires on those so I can take my good tires and store them in the house so I dont have to heat the garage when temps get to low.
Old 07-30-2019, 11:54 PM   #8
metros11
Drives: 2018 SS 1LE
You can also just put the car on jack stands and take the wheels/tires off.
Old 07-31-2019, 12:09 AM   #9
JCunningham
Drives: 2017 2SS M6
no that will damage the bushings
Old 08-08-2019, 02:04 PM   #10
wnyzl11le
wnyzl11le's Avatar
Drives: 2019 zl1 1le
Zl1 1LE 305 front 325 rears if you want them they are at my house. goodyears.
DM if you want them.
2018 GMC Denali 6.2L
2019 Camaro ZL1 1LE 6 speed Riverside Blue 1LE NAV PDR. PPF entire car
wnyzl11le is offline   Reply With Quote
