#1 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
wideband install
I was looking into installing a Innovate DLG-1 https://www.summitracing.com/parts/inn-3891/overview/ I looked it up on you tube and found the a video
POST 6000
![]() Drives: CMaro Join Date: Sep 2018
I put mine on my xpipe . Reads perfect
i also asked this in HP forum. tuner said no it wont read right behind the cat.
I just received the AEM 30-0334, and the instructions say the same thing, "Upstream of any catalytic converters". I know I've seen some headers that come with a Wideband port already welded into the collector (in addition to the O2 sensor bungs), but I can't remember if my Stainless Works headers have that. I guess I'll have to climb under there today and see, I'm doubting it. Sure would be nice though....
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
Did mine a few inches upstream of the primary cat on the driver's side.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
Does anyone know the brand of headers that has a wideband bung?
#7 |
My 2in from SE has 1 on the left header
#8 |
So is everyone running wiring all the way out to the fuse box for their switched power, or is there a more convenient source under the dash somewhere? I also notice it says to use a 5a fuse on that power source.
#9 |
ARH will put them in if you request it.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
WB needs to be installed before the cats, not after them. unless you want to have the tune be skewed.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
#11 |
I know the sensor is “supposed” to be installed before the cat, per the instructions. But why is it that when you go to a dyno, they stick the sensor up the tailpipe? Maybe a different sensor or something? I find it odd, because I’ve had a very well-known and respected tuner on this forum (who shall remain nameless) tell me to just install the sensor in one of the aft O2 ports behind the cat! He will be doing my tune. But maybe it’s because I have 2” headers w/ HF cats? Or maybe because my car is just a basic bolt-on car not pushing any crazy HP? I’m conflicted!
#12 |
I was told they know how far off there wideband is. But would different cats affect that?
#13 |
I don’t know, could be!?!?! Maybe because the HF cats have less restriction? I’m not sure which way to go now! I can’t see the cost of welding the bung in before the cat as being very expensive, so maybe I should just do it so there is no doubt.
#14 |
Ya wouldn't cost much but my headers are ceramic coated so I don't want to grind it off and have a hot spot.
