Old 04-16-2019, 06:04 PM   #1
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
Help comparing 2 tunes.
I am trying to understand the differences between 2 HPTuner tunes. When I open both .hpt tunes via the compare option, this is what it shows me. Main Spark vs. Airmass vs. Open Throttle, High Octane - this is on a 16 SS with a Magnuson, numbers look quite different.
Original tune
https://ibb.co/5WnJpt3
Updated tune
https://ibb.co/yRtPm5h
Differences
https://ibb.co/G55kDky
Can someone maybe explain what the differences would mean?
2016 Camaro SS A8 | Magnuson Heartbeat | Might Mouse Wild Catch Can | DSX Flex Fuel | Eibach Pro Kit | Flowmaster Outlaw Black Series | MRR 017 Wheels
Epx998 is offline   Reply With Quote
Old 04-16-2019, 06:10 PM   #2
TJay74
Looks like your tuner added some timing in the part throttle area of the table and then took some timing out of the table where the car nears WOT.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 04-16-2019, 06:27 PM   #3
Epx998
|Engineer|
Epx998's Avatar
What would taking timing out near WOT do to a car thats supercharged?
Old 04-16-2019, 09:02 PM   #4
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Without a log file and the actual tune, anything said would be pure speculation. If you want real help, you will post both.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 04-16-2019, 09:18 PM   #5
steelheadrob
Tactical Garage
steelheadrob's Avatar
The way I look at it to add power on a supercharged car you can either add boost or add timing, but to do either you need the octane to support it among other things. In this case your tuner is reducing timing at the upper rpms at WOT because at the upper boost levels the octane gas you are running cannot support both the boost levels seen at upper rpms and the timing seen at lower rpms.
steelheadrob is offline   Reply With Quote
Old 04-16-2019, 10:02 PM   #6
TJay74
This is spot on and the same way Ted over at Jannetty explained it to me as well. You can have 1 or the other, boost or timing but without the proper fuel system and fuel you cant have both.
Excess timing leads to increase combustion pressure and temps, increase combustion temps that are not kept in check with proper fueling can rise quickly and ring gaps that were once enough run out of room quick and then the next thing you know you have ring gaps touching and broken ring lands on the pistons.
What are your goals for this setup?
Old 04-18-2019, 09:33 AM   #7
steelheadrob
Tactical Garage
Rule of thumb from the procharger website "Higher octane fuel will allow you to run higher boost levels, approximately 1 psi for every 2 points of octane." The other rule of thumb is it takes 1 point of octane for every additional degree of timing.
Based on this, if you are at your octane limit, you will need to remove 2 degrees of timing for every additional 1 pound of boost you add.
