Old 04-15-2019, 08:41 PM   #1
s.hammer
Drives: 2015 Z/28
ZL1 1LE alignment questions
Curious what you guys are getting for max negative camber out of your fronts??? I am at -2.7 and butchered the outside edge of one of my fronts, rest of the tire is in fairly good condition. Way to much rubber left to have to scrap the tire so I definitely need more negative camber. Do I have to lower the front all the way to reach max neg. camber? Any input would be great.
Thanks
s.hammer is offline   Reply With Quote
Old 04-16-2019, 06:46 AM   #2
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Have you turned the strut top plate to the track position? Im at 2.9 and my wear seems good.
Lowering the front does not change camber. Only front height and spring pre tension.
breakskeet is offline   Reply With Quote
Old 04-16-2019, 03:53 PM   #3
s.hammer
Drives: 2015 Z/28
Yes, plates have been rotated to the track position, currently at -2.7. Al O in an interview stated -3.7 was possible.(link to vid attached)
Just wondering how to get closer to that...
Old 04-16-2019, 04:05 PM   #4
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
I'm at 2.7 and have even wear on my fronts. Might be an air pressure issue. What are you starting at and what is it when heated up?
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 04-16-2019, 04:27 PM   #5
s.hammer
Drives: 2015 Z/28
Starting somewhere between 29-31, and ending 38-41. Depending on temperature. Running on the high side pressure wise, which I would think would wear the center of the tire more than the outer edge. Outer edge wear indicators, (the goodyear symbol) is still there, just wore the outside inch, inch and a half of the tire.
Old 04-16-2019, 05:06 PM   #6
breakskeet
Kevin
breakskeet's Avatar
That's way too high I think. I would drop to 25-26 cold. Try to keep the hot presssure around 33-35.
With a hot pressure that high the tires are maybe sliding a lot during cornering and wearing the outside.
i would drop pressure and see what the wear is and add more camber.
Old 04-16-2019, 05:16 PM   #7
Sooner Cole
He's right ^ 26 cold start pressure, building to 32-35 on hot tires.
19 ZL1-1LE A10
Old 04-16-2019, 05:33 PM   #8
breakskeet
Kevin
breakskeet's Avatar
^^^^ Thanks! I've noticed that at 38 and above tires get pretty "greasy" and start to really slide around.
Old 04-16-2019, 05:35 PM   #9
s.hammer
Drives: 2015 Z/28
In my past experience, the lower the pressure, the more I roll over the side tread wear indicator, wearing the outer edge even quicker. But if there is no more negative camber to be had, I will be giving it a try. Thanks
Old 06-10-2019, 08:56 PM   #10
Apexslayer
Drives: Zl1 1le
I have the same wear issue on the front drivers side only. I have the track alignment, i start at 26 cold and end up around 33/34 hot, but I wear the outside edge of the drivers side tire very quickly (the strip that wears is only about 3mm wide and comes out in little chunks) while the rest of the tire wears evenly. Not sure what the issue is, but i'm going to see tomorrow if I can get more negative camber.
Apexslayer is offline   Reply With Quote
Old 06-10-2019, 11:05 PM   #11
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I've found the Supercar 3R's work best at 36-37 PSI hot. Once you get your pressures dialed in, then you can make a judgement on whether your alignment needs more negative camber based on wear and tire temps across the treadwidth. A tire pyrometer is critical to making an informed alignment decision.
Old 06-10-2019, 11:08 PM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Thanks
You get more negative camber by adjusting the knuckles, just like every Alpha platform alignment.
Old 06-11-2019, 10:14 AM   #13
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Camber and pressures will also be dependent on the track you are on as well. The GM recommended may be the best "all around". Play around with it, invest in a tire pyrometer and see what you come up with. Adds some fun coming up with your own set ups as well.
seanblurr is offline   Reply With Quote
Old 06-11-2019, 11:55 AM   #14
BAD MOOOFOOO
Drives: between cars
Originally Posted by seanblurr View Post
... invest in a tire pyrometer and see what you come up with.
Learned something new today.
BAD MOOOFOOO is offline   Reply With Quote
