Old 04-14-2019, 01:48 PM   #1
MrTee12
Drives: Camaro
Light surface scratch
Any advice on repair this? It's really light, not even fingernail deep.
My car is red hot. Is there any recommended touch-up paint brands that are credible or do I need to order from GM?
Thanks
MrTee12 is offline   Reply With Quote
Old 04-14-2019, 01:56 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Goto Drcolorchip.com- easy and effective
Old 04-14-2019, 06:56 PM   #3
CruzinQueen
CruzinQueen's Avatar
Drives: 2017 1LT RS Convertible V6 A8
IF you can't feel it with a fingernail then you may get by with a compound and polish. I'd try to machine it out first before going the touchup paint route. Good luck! Doesn't look too bad.
2017 Camaro 1LT RS V6 A8 Convertible - Silver Ice/Black Cloth, K&N CAI, MRT v. 2 Axle Back, Redline-style Badges and Wheel Hashes, American Authority Grille & a Whole Lot of Attitude
2019 GMC Terrain SLE 1.5T - Blue Steel Metallic/Black Cloth "Soccer Mom Spec"
CruzinQueen is offline   Reply With Quote
Old 04-15-2019, 09:57 AM   #4
SSport16
SSport16's Avatar
I would try to compound it with a D/A polisher and some good compound. I betcha you can get most if not all out with a few passes.
Old 04-15-2019, 12:41 PM   #5
KirkH
Or call a local detailer.
That's in a tough spot. The plastic fenders are tougher to buff out than the metal panels.
Some of it appears to be paint so that will come off pretty easily. Start with a claybar.
Then a dual action polisher with 3" orange pad with Meguiar's M110, followed by a white pad and Meguiar's M210.
Old 04-15-2019, 02:06 PM   #6
VinnAY
Drives: 18 1SS/1LE
I agree, if the damage can be felt with your fingernail, if it has en edge to it, then it's more complex. Some minor buffing can reduce the appearances but you're possibly looking at a touchup and even then it's not going to be invisible.
Old 04-17-2019, 01:32 AM   #7
peteric
Drives: 2016 camaro
If you need a touch-up paint, paintscratch is a good source.
peteric is offline   Reply With Quote
Old 04-17-2019, 01:52 PM   #8
Quix
Quix's Avatar
Drives: 2016 2LT V6 Garnet Red
That looks like it's just in the clear coat. I would try something like Meguiar's Ultimate Compound, hand applied with a little big of effort. If you do that, wax afterwards.
Quix is offline   Reply With Quote
Old 04-22-2019, 11:47 AM   #9
MrTee12
Drives: Camaro
Thx for the replies.
Old 04-23-2019, 12:01 AM   #10
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
If you can't feel it with your nail, it's most likely paint transfer. Get a small bottle of Carpro Fixer compound and use a yellow wax pad by hand if you don't have a machine. It leaves very little, if any marring after use. I wouldn't use Megs Ultimate, it tends to leave a lot of marring on softer paint, which on the plastic bumper covers, is always soft because this area is not baked on at the factory like the metal/aluminum painted areas.
Be sure to wash, and wipe the area down with IPA, prior to using compound. Once you have removed all the paint transfer, then you will be able to see the actual damage to the paint.
Wipe down again with IPA to remove residue and re-apply protection to area.
If it turns out to be deeper, here is your best touch up application.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 04-23-2019, 05:03 PM   #11
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
No one has brought this up yet? The new Optimum "clear coat in a bottle" stuff? Basically a wipe on clear coat that fills in the damaged areas. (If there is clear damage under the transfer.) Not cheap, but looks amazing.
https://youtu.be/7dWZkkc_G4E
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
