04-11-2019, 02:33 PM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
2016-2019 Camaro with Factory Ground Effects STO N SHO Removable Front License Plate
2016-2019 Camaro with Factory Ground Effects /1LE performance pack/50th Anniversary Edition SS STO N SHO Removable Front License Plate Bracket
$91.19 With Code PHIL5 At Checkout A common concern for all sixth generation Camaro owners is what do about a front license plate. The risk it in one of the states that require a front plate, never knowing when a police officer might spot you and give you a ticket. Would you drill holes in your front bumper to install a license plate hanger? What if you drive a 2016- 2019 Chevrolet Camaro then you are in luck if you want to have the best of both worlds. Our Camaro removal license plate mounting bracket from big Mike's performance allows you to run a front plate when you want to, and go without a plate when you do not need one. The STO-N-SHO Camaro removable license plate bracket does not require any drilling into your front bumper. Big Mike's Performance Parts' STO N SHO for 2016-2019 6th Generation Chevrolet Camaro 1LE, 50th Anniversary Edition, and SS Big Mike’s Performance Parts’ 6th Generation Camaro STO N SHO™ is an aftermarket quick release front license plate bracket that is designed for those cars whose appearance would be ruined by the use of the factory mounting location. Stay in compliance with state law by simply storing your front license plate when you want to SHO the beauty of your car. Big Mike’s Performance Parts’ STO N SHO™ is a two-piece quick release front license plate bracket consisting of a front license plate holder and a base mounting plate. Removal and installation of the front license plate is easy Requires only the pull of a spring-loaded pull pin The remaining base plate is virtually undetectable The STO N SHO aftermarket quick release front license plate bracket is manufactured in the USA using quality materials and parts. The front and base plates are precision laser cut and hand burnished. Each tube and rod is machine cut and hand cleaned. Each STO N SHO aftermarket quick release front license plate bracket is expertly hand welded and drilled. After it’s assembled the base plate welds are ground smooth. The bracket is then anodized black. The final step in the process is to install the pull pin and test the product. While the bracket may look simple in appearance, a lot of time and work goes into making each 6th Generation Camaro STO N SHO aftermarket quick release front license plate bracket to ensure you receive a quality built product. Constructed of 5052 and 6061 aluminum Welded and anodized black Built to last and comes with a limited lifetime warranty Big Mike’s Performance Parts” STO N SHO™ requires small holes to be drilled on the underside of your vehicle. These holes are not visible and in no way detract from the look of your car. Requires no holes to be drilled on the underside of the car 2016-2019 Camaro with 1LE performance package or factory ground effects 2017 Anniversary Edition Camaro SS All parts required for installation included, however, tools are required. *Actual bracket may vary based on the model https://www.rpidesigns.com/shop/item...plate-bracket/ |
11-04-2019, 02:05 PM | #2 |
