![]() Drives: 2019 2ss 1LE Join Date: Mar 2019
Pulling fuse for exhaust
How does this benefit you? If I want it loud all the time can't I just leave it on sport or track mode?
Retired from Car mfrs....
Do a search, the valves still close at interstate speed in sport and track, the fuse pull leaves them open all the time.
![]() Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
I tried it on mine last weekend. There is definitely a difference, especially coming off roundabouts and when applying light throttle on the highway, it seems to rumble a lot more. I like it, but I need the NPP functionality to put it in stealth where I park.
![]() Drives: C8 Corvette Join Date: Mar 2013
There is a big difference between no fuse and track mode. If you hold your speed in track the npp will still close the flaps partly to reduce noise. I'm not quite sure about the US models, but at least EU Models also don't open instantanously once you push the pedal if you were in city speed before. Without fuse you will hear the full exhaust note no matter how you drive.
I recommend a M2W box, so you can switch between OEM behaviour and no fuse. To me it is absolutely necessary to have the option to close the valves at times for the neighbors.
![]() Drives: 2018 SS 1LE Join Date: Jun 2018
Plenty of write-up's on this topic just search it.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
I'm not so sure about the partially closed on the valve flaps.. It was my understanding that they are only a two position solenoid control. In Track mode they are open fully when you are under any type of acceleration and close when only very light to no pedal is applied. I maybe wrong but I found no difference with the fuse pulled unless I was on flat road and just had a very light pedal. Correct me if I'm wrong on that one.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
#7 |
![]() Drives: '17 Red Hot 2SS 6MT Join Date: Mar 2018
And if you don't want to pay $80 for the M2W kit, then I will sell you this one for $20 shipped. It works as advertised, but the default is valves open (like the fuse pull), and I found that I was too lazy to push the button after each startup to set it back to tour mode. :-)
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I really haven’t noticed much of a difference in sound after the fuse pull on my ZL1. I guess because it is somewhat loud to begin with. I did set my exhaust to track mode.
#9 | |
![]() Drives: 2016 2SS 8AT Join Date: May 2018
#10 | |
#11 | |
directly too the opposite lead. I think the relay had a couple of solder points that we're not actual leads but ones that helped hold it to the board. Those will be the outer most ones. |
