Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Anyone tried Cutting the Bottum off the Stock CAI?
Rumors are its good for about 10 or 12 hp with a drop in K&N filter. Anyone done it yet and is it true?
![]() Drives: 2018 Hyper Blue 2SS convertible Join Date: Aug 2017
you mean turn it into a WAI? wouldn't that let heated engine compartment air in? I ask because my SS is sitting under a cover and it is snowing out.
2018 HBM 2SS CONVERTIBLE A8 |
![]() Drives: Hyper blue 1ss Join Date: Mar 2017
Yea that doesent sound right, you want your air box to be completely sealed on the bottom so the only air that’s coming is cool from the grill and good vents
Kooks headers, MBRP Cat back, Rotofab CAI, Primary cat delete, E85, MSD Intake Manifold, Ported TB, MMR Z28/MT’s.
Callaway Camaro is a cut bottom stock box and green filter.... Lingenfelter is a green filter... we are talking about the most expensive builders on the planet.... just saying.
https://www.camaro6.com/forums/showt...light=callaway "600 BHP 500 Lbs ft of torque Package includes: Engine removal, inspection and cleaning for assembly Lingenfelter CNC ported & polished LT1 cylinder heads Hollow stem 2.13-inch intake valves, 1.59-inch diameter exhaust valves Three angle valve job, hand blending of valve seats CC chambers, surface, set spring heights and assembly Lingenfelter dual valve springs, titanium retainers, 10 degree locks Lingenfelter Aggressive Idle hydraulic roller camshaft by Competition Cams Ported & polished throttle body High Flow Green Air Filter All necessary gaskets, fluids & bolts Professional assembly & engine installation Custom engine control module reprogramming Chassis dyno testing before & after installation Excellent drivability, highway mileage not adversely affected Lingenfelter 3 year/ 36,000 mile warranty Lingenfelter certificate of authenticity Lingenfelter chrome fender badges, interior badge & personalized stainless engine badge Four wheel alignment, cleaning & detailing, full tank of 93 Octane fuel before delivery "
#6 | |
Drives: 2017 Super Sport Cam. Join Date: Feb 2018
I'm waiting for someone else to try this before I try it.
#7 |
after the re-tune, why don't we see them put the stock cut box back in and see how much HP it loses? Just asking....
#8 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
https://www.camaro6.com/forums/showthread.php?t=541269 Can't say I felt much difference in performance. No dyno pulls to compare. Check out post #13 in the thread I posted above. The bottomless stock box did perform as well or slightly better on the dyno than some 3rd party intakes. Of course, having a supercharger I did hear more whine with the cut box. IATs sitting at a traffic light will definitely be a few dregrees higher with a cut box. However, as soon as the car starts moving they quickly return to 1-3 degrees above ambient while cruising.
