SITH SS
Drives: 2017 Camaro 2SS Convertible Join Date: Sep 2017
E85 with my Whipple on SBE?
My current mods are a 2.9 Whipple with 3.5 pulley, Rotofab dry, TSP 2” with cat deletes and MBRP axle back. Custom tune by Fasterproms. Car makes 614whp. I have a flex kit installed, but not enough fuel to run it. I’m about to add a SMG external low side, LT4 HPFP and LT4 injectors. I’ve been told on E85 this could put me in the 700whp range. Question is, am I flirting with disaster? I plan on doing the rotating assembly and cam next year, but not now. I’ve seen people breaking pistons on less power and I’ve seen people making 800+ on SBE without issue. Any feedback or personal experiences are invited and welcomed.
![]() Drives: 2015 Camaro 2SS 1LE Join Date: Apr 2015
I was one of the unfortunate ones who popped piston ring lands @ 6500 miles and I had the LT4 blower with a 2.6 pulley on it running 93 as well as a reputable tuner (around 580rwhp). I have a feeling I may of had bottom end problems on my car even if I had no supercharged as from what I understand the ring consistency from GM isn't solid.
Personally I'd do pistons before heading over 700rwhp but I drive my car hard. You may be able to get away with it for a year you may not, in my case when I blew ring lands my fix was basically a hone and putting weiscos in so the cost was the same had I done them before blowing up.
2015 2SS - Base A6 - Sold/Brother/Traded
2016 Camaro 2SS - A8 | MRC | NPP | 725rwhp - RIP 2015 2SS 1LE - RS/Sunroof Mods: Headers, Borla ATAK, intake - Sold 2018 M2 Exec - Current |
You will need a LPE big bore to run full e85 with a stock cam. I made right at 600 in 5th gear(A8) with 3.5 pulley, stock exhaust minus cat deletes, rotofab, lt5 throttle body, on E85. Fuel system is LT4 injectors, LPE big bore, ZL1 intank, jms booster.
attached is my Dyno graph. Notice The torque comes in softer, but pulls hard up top and carries well. It needs to spun higher imo. Overall I am pretty happy with it. I like how the torque comes in a little softer, I can hook this thing up prerty good on the street with my 305/35/20 555r. Pulled a 3.3 0-60 the other day first try on 50 degree roads. Pretty sure I can get it in the high 2's on the street with some practice. Moral of the story, put a fuel system in it and get it on a mix of E85. It will help them stock pistons live. You are running that thing on edge with the stock fuel system on 93 at that power imo.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 04-09-2019 at 10:45 PM. |
![]() Drives: 2018 Camaro ZL1, 2017 Z06/Z07 Join Date: Jan 2019
I semi agree with the above. The stock cam fuel lobe is going to need to be addressed, and I am not sure even the LPE big bore would get it there with the stock fuel lobe. You are definitely getting to the point where you should be addressing both the cam and pistons/rings/ring gaps.
___________________________________________
2018 ZL1, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, ATI Underdrive Pulley 673/688, 2017 Z06/Z07, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, IW 18% Underdrive Pulley 640/664, 2019 Mustang GT Perf Pkg. 1 |
#5 | |
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 04-10-2019 at 08:53 AM. |
#6 | |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Either way works. Personally, I am a fan of cam and no alky...straight pump and all is right in the world. Only takes about 8psi to run 700whp (with a8)... Either way works...probably a personal preference.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#7 | |
