Old 04-08-2019, 02:07 PM   #1
Stanimal
Stanimal's Avatar
Drives: 2019 Camaro ZL1 1LE
Rear Camber. Can't reach track settings.
Brought my car to get the track alignment done. The shop positioned the front struts to the Track Camber setting. I gave the shop the wheel alignment specs from the Chevy track preparation guide (front camber -2.7, rear camber -2.0). They said they couldn't get the rear camber past -1.2. Anyone else try to adjust rear camber to track settings?
Stanimal is offline   Reply With Quote
Old 04-08-2019, 02:12 PM   #2
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
2.7 on the front and 2.0 on the rear for me, no issues
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 04-08-2019, 02:48 PM   #3
Stanimal
Stanimal's Avatar
hmmm. And they seemed like good car people. Oh well. Time for a new tire place.
Old 04-08-2019, 02:53 PM   #4
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Yes, should be easy.
SFV1LE is offline   Reply With Quote
Old 04-08-2019, 03:59 PM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Find a new place that knows how to use eccentric adjusters. If they can only get -1.2°, they don't know what they're doing.
Old 04-09-2019, 08:04 AM   #6
BlueinTN
Drives: gas powered
Did they bounce the rear end a few times? Camber sometimes wont show right on the rack the tires scrub.
I bet after you drove it its closer to the -2 it should be.
BlueinTN is offline   Reply With Quote
Old 04-09-2019, 08:22 AM   #7
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Did they replace the control arm bolt? If not, that is a clue they have no idea what they are doing and did not open the service manual.
That bolt is the eccentric to turn...but is TTY single use bolt, must remove and discard... install new bolt turned to desired camber, then tq nut.
When the next person doe it right, make sure they put new bolts in. You don't want control arm bolts in there that have been yielded a couple times.
Russell James is offline   Reply With Quote
Old 04-10-2019, 08:04 PM   #8
Apexslayer
Drives: Zl1 1le
Dealer had no problem... ...plus pricing was reasonable.
Apexslayer is offline   Reply With Quote
