Old 04-08-2019, 09:57 AM   #1
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Where does the wideband go
Hey guys, just curious, how do you hook up your wideband sensor to etune? Do you just unhook a o2 sensor and replace it with the wideband, or do you need an extra bung to thread it into? I'm looking at headers and don't know if I need to find a set with 3 bungs, or just two for the o2 sensors. I've looked everywhere and haven't been able to find answer.
Old 04-08-2019, 10:20 AM   #2
Umbriel
Drives: 2016 Camaro SS
You will need to have an extra bung welded in for the wideband.
Umbriel is offline   Reply With Quote
Old 04-08-2019, 01:14 PM   #3
Booher
Booher's Avatar
Dang, I was afraid of that, thanks for the response.
Old 04-08-2019, 06:55 PM   #4
tom's2005gto
Drives: 2016 2SS A8 Convertible
Currently I am using a rear o2 sensor bung. My tuner recommended this and was able to tune accordingly
tom's2005gto is offline   Reply With Quote
Old 04-18-2019, 12:58 AM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
I asked on HP tuners forum. and directions for o2 gauge said it will be reading lean if after the cats. your probably running rich.
Old 04-18-2019, 07:27 AM   #6
lDejavul
lDejavul's Avatar
Drives: Camaro SS
Thats if you still have cats
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB
Pray ported MSD IM
Rotofab CAI
BTR 225 CAM
PRC 312 CC Ported Heads
Katech Oil Pump
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Full JLAudio Stereo Build w/ 13-W6
lDejavul is offline   Reply With Quote
Old 04-18-2019, 08:31 AM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
Just have your rear o2's turned off and remove them. You can use that bung for your wide band. Or anyone who knows how to weld can toss one in for pretty cheap, you can find the bungs on ebay for a few bucks
Juiced1 is offline   Reply With Quote
Old 04-18-2019, 11:37 AM   #8
JCunningham
Drives: 2017 2SS M6
it will read lean if put after the cats.
Old 07-24-2020, 08:03 AM   #9
pavetim
Drives: firebird
My understanding is for tuning you want your trims off anyways so can disconnect a sensor and add your wideband in. Then after tuning then trims back on. Sound right?
pavetim is offline   Reply With Quote
Old 07-24-2020, 08:31 AM   #10
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Much better off with an AEM wideband installed full time. That way you can log it with HP Tuners and see it on the street (on the gauge) too. Just weld in an extra bung into your header collector...done.
