Old 04-08-2019, 04:20 AM   #1
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
Quick and easy Oil question
For you folks that have changed your oil once or multiple times in your SS V-8 LT1.
Have you found that she takes the full 10 quarts?
Or, do you have to play around looking at the dip stick to see if she's over or underfilled?
I'm thinking just pour in the ten quarts and be done with it.
Reading the literature in the manual performance supplement, it states that you can run 11 quarts of oil when at the track.
It seems that there would be zero chance then of overfilling when changing your oil by just adding the ten quarts as stated in the manual, if you can run with eleven quarts at the track.
The Specialist is offline   Reply With Quote
Old 04-08-2019, 06:27 AM   #2
VinnAY
Drives: 18 1SS/1LE
You're lazy as hell.
Old 04-08-2019, 06:56 AM   #3
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
When changing the oil in any vehicle, one should always check the level after completing the job, and adjust as necessary.
I have only changed my SS oil once myself, so far. I put in 10 quarts and found that I needed to add a tad more to have it read full on the dipstick.
Emoto is offline   Reply With Quote
Old 04-08-2019, 08:12 AM   #4
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Changed the oil and filter.
Added 10 quarts.
Dipstick reads full.
Job done.
(People overthink some things way too much.)
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 04-08-2019, 02:21 PM   #5
The Specialist
OMG,, I'm sorry I asked this question. So lazy... I have not excuse.. LMAO
Old 04-08-2019, 05:46 PM   #6
HyperspaceTurd
HyperspaceTurd's Avatar
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport
Mine takes about 10.5 to read full.
You should give the oil a minute or five to settle before you check the level again.
HyperspaceTurd is offline   Reply With Quote
Old 04-08-2019, 11:41 PM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
When I changed the oil in my 2016 SS it would take 10 quarts with filter. That’s what the owners manual states the capacity is 10 quarts. I owned the SS for about 3 years and did the oil changes myself because I wanted to make sure it was done right!
