Old 04-06-2019, 07:39 AM   #1
psipops
psipops's Avatar
Drives: 2016 2SS
Normal operating Temperature
I don`t seem to be able to find what a 2016 SS operating temperature should be. Cars and trucks have been most efficient at 210 degrees for alot of years but my Camaro doesn`t run anywhere near that. Maybe 150 degrees. Anyone know for sure. The car is an A8.
psipops is offline   Reply With Quote
Old 04-06-2019, 09:00 AM   #2
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Are you the original owner? If not someone may have put in a cooler thermostat.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 04-06-2019, 10:14 AM   #3
psipops
psipops's Avatar
Drives: 2016 2SS
I am not the original owner, so I guess my question should be what temp should it run from the factory?
Old 04-06-2019, 12:42 PM   #4
6spdhyperblue
Drives: 2SS 1LE
190-215. It’s easy to get to the thermostat and see what’s in there
Old 04-07-2019, 05:28 PM   #5
psipops
psipops's Avatar
Drives: 2016 2SS
I found a post from 3/2017 that talked quite a bit about what we have here, so I went ahead and pulled the thermostat out. Not a big deal like you said. There looks like some numbering on the end of the stat bulb but not very readable at all. Anybody have a way to tell for sure what degree it is?
Old 04-07-2019, 05:37 PM   #6
Bigdog9586
Drives: 2016 Z06 coupe
You could put it in a pot of water and slowly bring it to a boil with a thermometer in the water. Read the temp when it opens.
Bigdog9586 is offline   Reply With Quote
Old 04-08-2019, 12:05 PM   #7
psipops
psipops's Avatar
Drives: 2016 2SS
Went to my local Chevy dealer this morning and found out that the stat from the factory is a 194 degree. Going to compare the dash gauge to the digital read out in the DIC and see what the comparison is.
Old 04-08-2019, 12:18 PM   #8
6spdhyperblue
Drives: 2SS 1LE
It is 194 but I can run cooler
Old 04-09-2019, 07:16 AM   #9
psipops
psipops's Avatar
Drives: 2016 2SS
Thanks for the help. I guess that is where I am according to the dash gauge. Isn`t there a digital gauge in the DIC? If there is I have n`t been able to access it. Is there a trick?
Old 04-09-2019, 07:31 AM   #10
6spdhyperblue
Drives: 2SS 1LE
I didn’t think so, if you don’t have a scanner get a WiFi obd2 scanner off amazon for $20 and use a free app on your phone to get the readout.
Or I heard GM stock replacements are $15. Not sure
